Results 1 to 9 of 9
    Dec 2006
    Confused Electric Heat Will not turn off
    Just moved into my condo about 6 months ago, replaced the old thermostat with a newer Hunter model # 42999B digital thermostat. AC worked great all summer long (I live in FL). I finially get around to turning on the Heat and it kicks on at the correct temp just fine, but it will not turn off (I hear the thermostat CLICK but the heat keeps on running). I even tried disconnecting the thermostat and removing it from the wall (just snaps off) the heat will continue to run and run - I usually wait at least 4-5 minutes before giving up - I know it can continue to run for several minutes after it's suppose to go off. The Heat/OFF/AC switch has no affect either, and lowering the temp has no affect.
    The only way I can turn off the heat is by turning off the circuit breaker, and waiting about 2 mintues, then I will hear a "click" from the Weathermaster eletric heat unit - then I can turn the breaker back on - and it stays off. If I turn on the breaker too soon the heat/fan comes right back on (even with thermostat removed!).
    I am guessing this has nothing to do with the thermostat, what should I start looking at on the eletric heat unit? I have an old Weathermaster model CFEAH18-10 unit.
    I have a basic 4 wire thermostat, One weird thing I tried lastnite was removing the jumper wire from the Rh and Rc on the thermostat - the unit will actually turn off ONCE automatically, but once it comes back on it won't turn off - I tested this 4 times!!! Then I have to manually reset the sequence with the circuit breaker.
    May 2003
    Sarasota. Fl
    The sequencer is sticking, call for service.
    It is the job of thinking people not to be on the side of the executioners.
    ~Albert Camus
    Florida
    Time for a service call, where a pro can get you a real t-stat instead of that Hunter, and check out the entire system, especially since you don't know how it's been maintained.
    Jan 2003
    Kentucky
    Quote Originally Posted by smokin68 View Post
    i don't care much for those Hunter's either ,but i would guess it to be a wiring issue
    Nov 2001
    east kansas
    Are you sure the heat is still on? Or are you expecting the heat and blower to shut off as soon as you turn the heat off?
    IOW, how do you know the heat is still on besides hearing the blower run. Are you overheating your condo?
    And why the **** would you stick a piece of **** Hunter or Lux for that matter in your condo. They are nothing but trash.
    Dec 2006
    Um yes, hot air is coming out, and if I ignore it, the condo gets quite toasty. The temp will rise into the 80's if I leave it (and it has).
    Hunter makes a great fan.
    Doesn't mean they make anything else as good though.
    Miami mike's right on both counts get a service man
    Jun 2001
    Louisville, KY
