Results 1 to 6 of 6
    May 2005
    883060 true t-stat instructions needed
    i ordered a t-state for a old true 2 door freezer
    i came with a relay and some new wiring, and no instructions..
    true is closed
    anyone got these instal instructions?
    Oct 2011
    Chicagoland Area
    If there is a Grasslin clock in the unit you need the relay. If it's a Paragon you don't. The relay was added because the inrush of current was causing the contacts on the Grasslin timers to weld. Someone here might have a wiring diagram. Wish I could be more help The relay would be located in the chase the compressor pugs into
    May 2005
    it has a regular 8141-00 timer..so i can just replace the t-stat then??
    Oct 2011
    Chicagoland Area
    Yes.
    Jul 2000
    Guayaquil, EC
    Here's a link in the Educational Forums for the 2007 True Service Manual which has a section on temperature controls which covers those relays:
    http://hvac-talk.com/vbb/showthread....-Manufacturing
    If the new thermostat is a Danfoss and the compressor is larger than a 1/3 hp, you will need the relay.
    May 2005
    wow, thanks icemeister..
