Results 1 to 9 of 9
Thread: 4 WAY Valve?
    Jul 2012
    Phoenix, AZ
    4 WAY Valve?
    Hey everyone had a quick question about 4 way valves. Still new in the field learning as I'm going, and I've come across a problem with a 4 way valve in the field. I'm unsure on how to test to see if my valve is working properly, and was wondering if any of you had any ideas on how to troubleshoot problems like this?
    Jul 2012
    Cincinnati ohio
    Quote Originally Posted by jjmarquez84 View Post
    How do you know you have a problem with it?
    Phoenix,AZ
    If it's stuck in the middle you'll hear it hissing and suction psi high, discharge low! If it don't shift at all! Well, that's pretty much a no brainer!!!
    Mount Airy, MD
    Temp split in between common ports.
    3-5 suction and 5-10 discharge tops.
    Jul 2012
    Phoenix, AZ
    Awesome thanks for the feed back brother.
    Jul 2012
    Phoenix, AZ
    3-5 Suction I remember in school them talking about when testing the 4 way valve, but the 5-10 discharge why is that gunna be a higher reading
    Jun 2007
    Greenwood Indiana (Indianapolis)
    We call em' reversing valves.
    As iron sharpens iron so one man sharpens another Proverbs 27:17 NIV84
    Salisbury, Maryland
    5-10 temp drop from discharge inlet to reversing valve to outlet of valve depending on which mode its in(far right or far left tube). Remember, if the valve is stuck your gonna be gaining heat into the suction stream and you will also have a temp drop across the discharge line through the reversing valve.
    Jul 2012
    Phoenix, AZ
    Awesome thanks guys for all the great advise and tips. I'll keep you all up dated on the repair.
