Results 1 to 13 of 16
    Nov 2011
    St. Louis
    Acetylene explosion
    Saw pictures of a different one in school when a leaking tank was allowed to fill up a van and a remote was used to unlock the door...incredible damage to nearby homes.
    http://news.yahoo.com/video/bizarre-...210013113.html
    Here'the one I saw in school...
    http://search.yahoo.com/search;_ylt=...8&fr=fptb-yie8
    Aug 2012
    Always close the valve when finished. He probably had it rolling around in there too.
    It's not if your doing it right it's whether your doing the right thing that is important.
    Nov 2011
    St. Louis
    I irritated a senior installer once by closing my valve when I was done outside and carted the rig inside. I don't trust the torch knobs for any length of time and keep the valve wrench poised to be slapped off in an instant.
    Aug 2012
    I turn it off in between welds for many reasons.
    Mar 2009
    Mid-Mo
    That's just scary.....
    Aug 2012
    Ryan welcome to the discussion. You obviously don't have too much time on your hands like some, me.
    Mar 2009
    Mid-Mo
    Seemed like you guys have it pretty well under control anyway. I haven't used my torch set in forever anyway!!!
    Aug 2012
    I heard that one anyways back to work.
    Oct 2009
    When working with Acetylene You need to know the "no no's", Ya know.
    Same with O2.
    And these gasses are not regulated.
    Not that I want them to be.
    Never argue with a crazy man.
    Belize
    Any one heard of "redtek"? Its the HC (R12a) replacement for R134a . "Redtek" is not acetylene but its a hydrocarbon and it will fuel a fire. I wonder would happen if a vehicle charge with "redtek" had an evaporator leak , and someone press the remote to open the car?
    Calgary, Alberta
    Quote Originally Posted by OStaine View Post
    Nothing.
    R-143a's replacement, HFO-1234yf is a flammable gas and has been proven to not be ignitable under even the most abnormal conditions.
    Redtek is perfectly safe, look it up.
    Belize
    I've had some training and read some articles on this subject. There are strict guidelines concerning the application of hydrocarbon in supermarkets and there are strict guidelines to remove all SOI's (source of ignition) from inside RTU's that are to be retrofitted. These guidelines were expressly given because of safety issues. Here's a video that follows my argument. http://www.youtube.com/watch?feature...&v=k0K1WPCWm2k
    Have you tried this with REDTEK?
    Oct 2009
    http://www.redtek.com/techinfo.html
    This looks like a crime to me.
    SECTION 3 – FIRE OR EXPLOSION HAZARD
    AUTO – IGNITION TEMPERATURE: 1585 F
    FLASHPOINT: -34 C
    LOWER FLAMMABLE LIMIT (LEL): 1.9%
    UPPER FLAMMABLE LIMIT (UEL): 8.5%
    EXTINGUISH MEDIA: If possible, stop flow of gas. Use water to cool fire – exposed tanks, surroundings and to protect personnel
    working on shutoff. Water spray, dry powder, or carbon dioxide can be directed at flame area to reduce fire intensity. Do not extinguish
    flames unless leak can be stopped.
    HAZARDOUS COMBUSTION PRODUCTS: Normal combustion forms oxides of carbon.
    SENSITIVITY TO STATIC DISCHARGE: Vapor may ignite if exposed to static discharge.
    EXPLOSION DATA: Sensitivity to impact. Mixture is not sensitivity.
    FIRE AND EXPLOSION HAZARD: Flammable vapor may form if allowed to mix with air. Accumulation of gas is an ignition hazard.
    Vapors are heavier than air and may travel to an ignition source.
