Results 14 to 22 of 22
    south louisiana
    Name:  4inch media filter to fit in regular return air filter grill.jpg
    I'll leave your question to be answered by bamacool.
    just wanted to tell you that media filters can be used in the
    return air filter grill you have. without having to change the
    r/a filter grill to accomidate media filter.
    check with hvac supply house, or with your hvac company
    for filters like the one in the pic attached.
    if you to upsize the return duct & r/a filter grill..
    use the filter grill that is made for media filters.
    I use 20x25x4 for my 2 ton system.
    best of luck
    Feb 2011
    Jun 2011
    New Braunfels, TX
    Quote Originally Posted by Calgary-hvac View Post
    Why not just buy new cells and use the electronic filter the way it was designed?
    Because the EAC does not do a good job filtering everything, and they are a PAIN to clean. If you have smoke they do an ok job of clearing that but I would still recommend a large pleated media filter like the others have mentioned.
    Calgary_hvac
    Jan 2013
    Thanks...I inserted a 20x25x4 pleated filter into the slot where the electronic filter components reside at the air handler...it is a MERV 12 rated filter. I also have a 20x30x1 in the return air grate in the hallway ceiling which leads up to the air handler. I was told that the Honeywell electronic air filter components can be replaced by the pleated filter. I hope that is correct information.
    Jan 2013
    Thanks...I inserted a 20x25x4 pleated filter into the slot where the electronic components reside in the Honeywell electronic air filter located inline at the air handler. I was told that was acceptable...I hope that is correct information. I also have a 20x30x1 pleated filter in the return air grate located in the ceiling leading to the air handler...
    burlington county n.j.
    i would remove the filter at the grill if you're still using a merv12 filter there, too much restriction to airflow with 2 filters.
    if you want a filter at the grill just use the fiberglass filters, no pleated filter.
    Jan 2013
    I have inserted the pleated filter in the EAC....I should leave it unplugged...correct?
    Quote Originally Posted by Qballgreg View Post
    yes, no power to eac when using media filter.
