Results 14 to 26 of 26
    Dec 2008
    New York, ny
    Quote Originally Posted by anthonyac1 View Post
    this might be stupid but ive seen it happen plenty of times. im sure you checked it but im throwing this out there anyways. your low side gage is not peircing the low side or very little. what makes me say that is when you add refrigerant your low side stays above 100psig so it looks like the pressure is not going anywhere also you mentioned the suction port is freezing sounds like the refrigerant is misting through the valve core slowly. causeing it to act as a metering device and getting really cold.
    +1 happened to me a few times..
    Sent from my SGH-T999 using Tapatalk 2
    Mar 2011
    Long Beach, CA
    Maybe if we all just listen Feng will teach us something new. Give him a chance and let him speak.
    I am so excited!!!!
    I hate those low loss fittings sometimes.
    Palmyra, Missouri, United States
    Sounds like above mentioned. You are probably not fully piercing the service port. Inside your hose is the fitting that presses in the core. Use your needle nose pliers and pull it out a little bit (out of your hose). Or loosen the core (tighten when done) or replace the core.
    May 2011
    Western, KY
    Quote Originally Posted by fengshvac View Post
    ha ha ha ha ha ha ha, very very good, good idea, yes, good idea
    FENG yay, hey I know you've gotten a hard time in some of your posts, by the way it's because you tried to do a tutorial as you would for a lamen but for guys who do this every day for a living.
    I hope you keep posting, you will get a ribbing but it's fun and you lighten up the forum a bit.
    Good luck fengshvac, keep working and learning everyday.
    May 2008
    Meridian, MS
    sorry I had to leave for a minute. I bet you are right - not piercing. I'll check first thing. thanks to all.
    td55
    Dec 2008
    Buffalo NY
    Quote Originally Posted by alcomech View Post
    I am so excited!!!!
    That's what I meant. He seems like a good guy who wants to show his talents.
    Join http://scopeny.org/ Shooter’s Committee on Political Education
    The world is full of sheep,try not to join the flock.
    Support the Skilled Trades, Don't DIY
    Jul 2009
    Columbia, MD
    is this a scroll or recip?
    if it's a scroll i believe it needs more then 50% of charge to work. use your recovery machine to pump the refrigerant into the unit.
    if still reading funky it's either your gauges or r/v.
    Oct 2005
    B.C. Canada
    Quote Originally Posted by gravity View Post
    Never heard that one before, about the50% thing, intresting, im sure ive charged scrolls with less than that while running
    Dec 2008
    New York, ny
    Quote Originally Posted by coolerik View Post
    +1
    Jul 2010
    wisconsin
    Had this happen on a minisplit last summer, good hard lesson learned
    indiana
    how much 22 did you remove when you changed bad compressor?
    Sep 2006
    Ohio
    If it's a scroll, I'm sure you already checked to see if it is running backwards, but just throwing it out there.
    up in the hizzy
    Quote Originally Posted by tonydykes55 View Post
    I pulled the connector off the RV solenoid. I can hear it energizing. the coil is good.
    with suction and discharge pressures almost equal the reversing valve is not going to shift. I think there is a restriction somewhere and that was what got the first compressor killed.
