Results 27 to 39 of 41
Thread: I am SO confused...
01-28-2013, 11:58 PM #27Heating/Cooling Services Inc.
www.andersonhvacservice.com
01-29-2013, 05:57 AM #28
Professional Member*
- Jul 2006
- Virginia
- 3,713
time to take your new thermostat with you to a new place to live
01-29-2013, 08:50 AM #29
- Jan 2013
- 17
The airflow isn't affected, though :-/ The air is moving just like it was (better than move-in day), it's just coming out at a strange temperature in one room. The only thing I did was turn off the unit from the breaker and swap thermostats, and then *poof* hot air blows in one room like the heater's on.
01-29-2013, 09:06 AM #30
As you probably allready know your first mistake was moving to that complex, your second mistake was touching the unit and your third mistake was telling them you touched it and your fourth mistake is you are not demanding proper services. I am not a lawyer but time to review your tenants rights. Good luck.
Certified parts changer.
01-29-2013, 09:09 AM #31
- Jan 2013
- 17
Is it possible for the heat to run simultaneously with cooling, but only the heat blowing to one room?
01-29-2013, 09:19 AM #32
Give up the ghost. At this point you have dug a hole for yourself and you are still digging. I reiterate what I have allready posted although you probably didn't like it I think it is very sound advise. TENANTS RIGHTS in your state.
01-29-2013, 09:20 AM #33
Since you refuse to answer my question that I asked a while back. I'm done. I was trying to help you as much as possible without breaking site rules because of your situation.
01-29-2013, 09:31 AM #34
- Jan 2013
- 17
01-29-2013, 09:39 AM #35
01-29-2013, 09:48 AM #36
- Jan 2013
- 17
You throw those away every day? Well, that would actually explain a little. I looked up local suppliers and found walmart, for around $20. Is it possible for the thermostat to be defective? A short somewhere? Because last night, I replaced the new thermostat with the old one, just to see if it would be the problem. Warm air was still blowing out of the vent, but I also only let it run for a couple minutes. I put my hand up to feel the temperature and it was warm, not hot, but warm. So I figured it wasn't the thermostat. Is it possible I just didn't let it run long enough?
The room that is getting hot/warm air with the ac running holds the vent that is the path of least resistance from the unit. It's the only vent that's a straight shot from the unit...
01-29-2013, 09:57 AM #37
- Jan 2013
- 17
It's not that I didn't think it was sound advice, but it doesn't really help right now... I mean, it does, but while I'm battling with the complex (which, I had an agreement with the complex that I would be allowed to do any repairs considered "basic home maintenance") and if I end up going through the court system, I'm stuck with this room that's unbearable and not livable until that one week in min-Feb when Florida temps finally decide to drop, and then it's back to being a useless room. I'm just trying to gather enough information to figure out how to fix it myself so I can get back to working at my desk.
I'm not looking to be walked through the process, I just need to know where to start looking so I can figure out how to fix it. This isn't my first time renting, and this isn't my first time renting in a place that refuse to fix things. I would love to not live here. I would. But I can't afford a better place. Tennants rights are great to know, but they don't fix the problem right now.
01-29-2013, 12:14 PM #38
Best place to start is in the PHONE book under ac repair and service. Pay out of your own pocket since nobody wants to help you, then deal with the slumlord you rent from.
01-29-2013, 12:35 PM #39
- Jan 2013
- 17
I did. I called and email multiple professional repair companies and none of them want to touch it because I'm renting and not the owner of the property. The reason why I'm on here trying to figure out how to do this myself is because I HAVE NO OTHER OPTION except craigslist. And I'll risk doing this myself before hiring someone off there.
