Results 14 to 18 of 18
    Feb 2011
    Fogelsville, Pa.
    Yea still looking for manual. The web site for Airxchange doesn't have it. I have to call.
    Jul 2012
    Western KY
    OEM belt should have distructions with it, should. Call manufacturer and have them email manual if google cant find it. Good luck.
    Mar 2010
    Tidewater Virginia
    I've got a set of Thybar ERVs which use a one piece "rubber band" style belt and remove the inner side bearing from the plate and shaft to loop the belt over the end of the wheel shaft during replacement. It's not too bad a job, especially since the wheel cartidge slides out as an assembly. Check with your supplier for an IOM.
    Feb 2011
    Fogelsville, Pa.
    Completed job. Wasn't too bad. Had to pull two segments of wheel and remove the bearing to slip the belt over the shaft. Boy a piece together belt would be a lot faster, not sure how good it will work or last with a belt tensioner and all.
    Jan 2013
    Central Arkansas
    Ditto for me. We have installed and still service 3 SEMCO air handlers with 8 1/2' ERV wheels. They use link belts that are clipped on site
    What do you think of the SEMCO wheels? Before I changed jobs I worked in the Arkansas plant where the wheels are built, I did not work in that department but have worked on lots of the units in the electrical end.
