Results 1 to 8 of 8
Thread: RTU trouble
01-27-2013, 06:08 AM #1
- Dec 2005
- NOrthern Ohio
- 37
RTU trouble
We have some trble on a rooftop unit, and techs have been out 4 times. When I go to the stat and set mode to "off",unit continues to run and fan blows cold air. I throw the breaker for a minute or two, then the unit heats fine for a few days. Then problem returns, no error codes are displayed on the unit. Thanks
01-27-2013, 07:01 AM #2
Made this its own thread. You are not allowed to post in other peoples threads in the AOP forums, please read our site rules, thank you.
02-19-2013, 01:02 AM #3
02-19-2013, 05:53 AM #4
ddcbacnet
02-19-2013, 08:07 AM #5
Sounds like a safety is tripping somewhere you need to check it instead of throwing breaker.
Certified parts changer.
02-19-2013, 10:35 AM #6
I advise that a professional should be brought in to see what is going on inside the unit.
02-19-2013, 01:53 PM #7
- Dec 2005
- NOrthern Ohio
- 37
I am a non AOP member, guess I posted this thread in the wrong forum, although for the life of my I cant figure out how to move it or close it. Dont want to get booted off of here. Pretty good info. Thanks for the info, but I am not pursuing this issue on this forum any further.
02-19-2013, 05:59 PM #8
You've done nothing wrong.
My earlier post on this thread was directed at another, non-AOP member that posted here.
As far as what type of problem you're having, I just had got done struggling with a problem that sounds very similar to that and found an issue with damaged wiring. It took me several hours of lying on the roof in single-digit weather to find and repair the issue.
There's HVAC 'guys' and HVAC-Professionals. Find a Professional to repair your problem
