Results 1 to 8 of 8
Thread: RTU trouble
    NOrthern Ohio
    RTU trouble
    Quote Originally Posted by meplumber View Post
    We have some trble on a rooftop unit, and techs have been out 4 times. When I go to the stat and set mode to "off",unit continues to run and fan blows cold air. I throw the breaker for a minute or two, then the unit heats fine for a few days. Then problem returns, no error codes are displayed on the unit. Thanks
    Made this its own thread. You are not allowed to post in other peoples threads in the AOP forums, please read our site rules, thank you.
    Feb 2013
    Vancouver, BC
    Additional infractions may result in loss of posting privileges.
    ddcbacnet
    Aug 2012
    Sounds like a safety is tripping somewhere you need to check it instead of throwing breaker.
    It's not if your doing it right it's whether your doing the right thing that is important.
    Southeastern Pa
    I advise that a professional should be brought in to see what is going on inside the unit.
    NOrthern Ohio
    I am a non AOP member, guess I posted this thread in the wrong forum, although for the life of my I cant figure out how to move it or close it. Dont want to get booted off of here. Pretty good info. Thanks for the info, but I am not pursuing this issue on this forum any further.
    Quote Originally Posted by bubb1957 View Post
    You've done nothing wrong.
    My earlier post on this thread was directed at another, non-AOP member that posted here.
    As far as what type of problem you're having, I just had got done struggling with a problem that sounds very similar to that and found an issue with damaged wiring. It took me several hours of lying on the roof in single-digit weather to find and repair the issue.
    There's HVAC 'guys' and HVAC-Professionals. Find a Professional to repair your problem
