Results 1 to 13 of 18
    5yo Trane VS AH Paired w/ a new Tempstar txt+?
    I have a nice Trane AH w/ an EAF, it's a 2007/8 model (TEE prefix). It has the coils and is all set for a HP -- currently electric heat only ($$$). Can I pair this w/ a new Tempstar 2-stage unit, while also making use of the Trane's VS fan (assuming use of a very capable t-stat)? Humidity control would be nice as well.
    I can't afford the Xl16 now. I'd also like to reward Tempstar because of how happy I was w/ it's performance and reliability at my previous house.
    1000 feet elevation in Willamette valley of the Pacific Northwest, so all about the HSPF - cooling is an added luxury for a few days out of the year.
    (1600 sq ft ranch)
    Is it a 4TEE meant for R410a? If so you could use another brand but you'd be far better off staying American Standard or Trane. I'd rather have a more basic matching unit like an XR15 than mismatch a 2 stage of another brand.
    Aug 2010
    West Monroe, LA
    I agree with BaldLonnie. I would not hook up another brand to your air handler other than Trane or American standard (same units). Look into the XR 15 Heat Pump.
    That would be a perfect match with your Trane variable speed electric air handler. Also If you are leaning towards (2) stage ask about the XR 16 model. Since the XL 16 is out of your budget, the XR 16 is the same unit minus the top and few other minor things.
    The Trane unit you have has it already been installed or do you just have it ready to be installed?
    Quote Originally Posted by duckman06 View Post
    Yes, it was installed 5 years ago when new.
    Yes, it is a 4TEE3F31B1000AA. Filter is an F300A2020. Heater is an BAYHTR1410+++. 3k btu, 2-ton.
    Trying to learn more about how this all works, so some questions:
    o Is this older Trane VS AH a "perfect match" w/ the XR16? Is this AH just as effective in maximizing efficiency as a brand new matched AH?
    o Will I be able to take advantage of any local or Federal govt. incentives w/ this "old" AH and the new XR16? (not a show stopper tho)
    o With regards to the Tempstar, what makes it a mismatch. Intuitively, I'm thinking of mis-communication between HP and AH (tho you can use a generic Honeywell t-stat?). Also, I'm thinking that the line set would need some adapters to the coils and other small variations?
    Why can't a good thermostat vary the AH's fan speed w/ the heat pump.
    Thanks for any additional info for this layman.
    Aug 2010
    West Monroe, LA
    Quote Originally Posted by SqueakyDog View Post
    To answer your question. I can't find a match on Trane website (dealers) for that matchup but that doesn't surprise me as they have updated all the info to match with the new Hyperion air handlers.
    I can say that I had installed a lot of XR15 heat pumps a few years back with that air handler which at that time was a good match. That was with the XR 15 heat pump. I have never seen the match up with that air handler with a XR16 but again doesn't surprise me as that air handler is not being made anymore.
    The best thing to do would be talk to the installing contractor and get them to research Ahri for matches with XR15 unit. I am not at my office but I am sure I have Ahri cert. that shows the match along with the number.
    As as the federal tax credit goes the XR15 or XR16 should be eliable the problem you have is you are pairing with a 5 year old air handler that was already bought before the tax credit was available. I guess you could always still apply and get the credit depending on how the dealer writes up the invoice. I would NOT do this though. The one person you don't want to mesh with is Uncle Sam or the IRS.
    I have a (2.5) ton XR 15 in my home with the same design air handler but the model is 4TEE3F037 air handler. You have the next smallest air handler which can be used with a 2-2.5ton XR15 that much I know for sure. My match up gave me 15.75 seer and I belive 9.0 hspf. It would just be best to talk to your installer as they will be the ones that will install, warranty and can tell you for 100% that the system will match up.
    As far as trying to pair the tempstar unit with the Trane air handler? Think of it like this, it would be like putting a ford transmission in a toyota truck sure it can be made to work but for how long. You would be opening up yourself to problems that don't want.
    Thanks so much, duckMan (et al)! Very much appreciate it. Still more questions on the mismatch stuff but that's only because I haven't done my research. I'll save up some cash and maybe next year check out the XR16, or perhaps the next future compatible Inverter HP.
    Aug 2010
    West Monroe, LA
    No problem!!! If you need the system now the XR15 is still a good choice or even a Xb14 for that matter. The only thing you have going against you is the cost of the outdoor unit going up.
    If you do Chosse to wait. Please at least talk to the installer about a new Hyperion air handler that Trane is offering now. This is what took the place of your current model unit. After a few minor problems for the most part all the bugs have been worked out. I have installed at least 30 of them with great results.
    As if push comes to shove you can look at a XB 13 or XR13 with a heat pump and should have no problems getting at least 14 seer out of them with your current air handler. If price is the problem please look into this models. They are nothing fancy just base heat pumps but when paired with a variable speed air handler can get distance eff. numbers and might turn out to be just what you are looking for.
    Anderson SC
    and a xb13/xr13 heat pump will be ~ 3 times cheaper to operate in heat than your current electric furnace.
    Heating/Cooling Services Inc.
    www.andersonhvacservice.com
    Yes, it would work. Most likely it would work quite well.
    The problem is that it is anyone's guess as to what the actual efficiency and capacity of the resulting system would be.
    Good to know.
    How does a single-stage HP work w/ the VS AH? Doesn't the AH fan and HP run full on or full off (for ST HP)?
    Anderson SC
    basically yeah, It will can use a different speed for heat mode, ac mode and continuous fan. Most newer equipment comes with a variable speed blower motor (x13 or ECM) and they use less power to operate than a traditional fixed speed or multispeed PSC (permanent split capacitor) motor. VS air handlers are used all the time on single stage hp, their are little savings in a 2 stage heat pump it is used mainly for increased comfort rather than a return on investment over a single stage unit.
