Results 1 to 13 of 26
Thread: Classy
    Calgary, Alberta
    Classy
    [ATTACH]350181[/ATTACH
    Who says things were done better 20 years ago?
    I think that big loop helps shoot the oil back into the compressor.
    Jan 2013
    Henderson, NV
    Installer was a big roller coaster fan!
    Float'N Vally, MS
    Quote Originally Posted by syndicated View Post
    I haven't seen one of those Coleman units in 20 years!
    Life is too short, Behappy!
    TFMM
    Apr 2003
    Maple Grove, MN
    I'm coming to the defense of that install. I believe that is a pre-charged line-set. You aren't supposed to cut those. Therefore, any extra line-set that you have needs to be left coiled up in a big mess. That's the way they wanted it back then.
    Calgary, Alberta
    I've heard tale from the older guys about such things. How did one go about connecting the lineset and releasing the charge?
    May 2009
    Cumming, GA
    It's just a version of an inverted trap!
    A really crappy version.
    Mar 2009
    Mid-Mo
    Quote Originally Posted by ammoniadog View Post
    I would still take the extra time to cut it and make it look nice. I'm OCD about things like that.
    They could have at least tried to use a bender on it.
    Jan 2011
    Quote Originally Posted by ryan1088 View Post
    You would have been screwed if you cut it. The line sets weren't copper. If you cut them they were ruined. If I remember correctly we could get 25, 35 and 50' sets.
    Mar 2009
    Mid-Mo
    Quote Originally Posted by KnewYork View Post
    Certainly wouldn't have been the first thin I screwed up doing this type of work. Obviously I've never used them and never will.
    Nov 2011
    St. Louis
    So was there a flared/compression type fitting that held the charge until you tightened the joint? I can't believe those things lasted too long...maybe meant for builder installs?
    Cincinnati, Oh
    Are you talking about those flexible liquid lines they used to make?
    I ran into that once in a concealed application. Not to happy.
    "Just get it done son."
    Dad adjusted
    Aug 2009
    Beatrice, NE
    We used all sorts of precharged line sets, they were all copper, Aeroquip fittings on the ends. We cut them to length, soldered them back together, vacuum pumped them and thighetened them up. Never had a problem.
    The only problem with them was the Aeroquip fittings didn't like to seal if you took them apart and tried to put them back together. For some reason it seamed liike half the time they would leak the second time around.
    oh, you yungins got a lot to see, wait until you cross a lennox that used the liquid line as the metering device and there is an extra 20' of liquid line
    at least they followed mfg instruction an d sloped the lines and didn't stand them vertical
    yea they could have made it look a tad better (not by much though)
