Results 1 to 13 of 13
    Jan 2013
    Noisy Oil Burners
    I purchased a new thermo Pride high efficiency oil furnace, and it is so loud I can't hear my TV when it comes on. I was told this is bvecause the rapid rush of air for efficiency. Can anything be done? Are other new furnaces just as lud. We had two in the past 22 years, and neither was loud
    Jan 2006
    Powell River, BC, Canada
    Is it the burner that is noisy or is it the main blower?
    Where are you? Are you done yet? I got ONE more call for you.....
    Moved to AOP Residential forum.
    Aug 2001
    Pavilion, NY
    That is not normal. While thermipride IMO is the best if the best, there can be some noise issues with the burners. Is this a Riello or a Beckett burner? Usually with proper adjustment and an outside air intake kit they can be very quiet.
    I'm guessing its blower/duct air noise he is hearing.
    Dec 2010
    WV
    Quote Originally Posted by kangaroogod View Post
    ageee Thermopride is THE BEST oil furnace in my opinion. but the real question is why is this your 3rd furnace in 22yrs? thats NOT OK....i have units out there , that i did not install, that are going on 40yrs old....possible duct issues overheating your furnace(3rd unit) and making high static pressure causing the system to sound like a "jet airplane taking off" when running..how bout model#.......................just looked up some info and ur unit may have a ECM motor in it, and that will make a difference in sound if its not set exactly right...betting thats ur problem....model# plz
    I'm gonna say you probably have undersized ductwork, this will cuse premature failure of heat exchanger and noise issues as others have stated.
    Jan 2013
    It is a Beckett, model # OH8FA119D60B
    Jan 2013
    Both of the earlier furnaces had cracked fire box. Interesting, the furnace is a backup to a heat pump, and does not come on until temperature is below 35*. The fan supports the air conditioner, the heat pump, and the furnace. If I keep the fan on all the time, there is not any noticeable noise. No noticeable oise when the heat pump is running, or the air conditioner. Only when the oil furnace kicks on below 35*, which just started in our area two weeks ago.
    Thanks for responding.
    Looks like the model number of the furnace, not the burner.
    What size is the heat pump.
    You need to have an oil tech out to perform a combustion analysis and smoke test to tune the furnace and it will purr like a kitten, save oil, and last a long time as long as the ductwork is adequate.
    Jan 2013
    Going deaf
    A few more facts may help. When the het pump is on becasue the temp is above 35*, no noise can be heard. When the burner initially comes on because the temp is below 35*, you can hear the burner, but not annoyingly loud. Within about 30 seconds, you hear a suction like a jet engine sucking air rapidly. It is most apparent by a flapper called "Calibrated Draft Control". This flapper is part of a vent from the furnace to the cinder block wall. It does not go outside at that point, so I think it goes into the chimney, which has 2 stacks. I should probably go outside and see if I see anything coming out that smokestack. When the burner turns off, and the furnace is cooling, the fan noise is also not loud. That's the best information I can provide, unless you need something specific that I can meassure.
    Thanks for replying.
    x2
    Heating/Cooling Services Inc.
    www.heatingandcoolingservicesinc.com
