Results 1 to 9 of 9
01-24-2013, 11:22 PM #1
- Jan 2013
- 7
Amana AMH95 2 stage multi speed vs Goodman GMVM96 Variable Speed Modulating
Looking for advice on choosing between the Amana 2 stage multi speed gas furnace and the Goodman Variable Speed Modulating gas furnace.
I live in a small ranch house, approximately 937 square feet in Upstate NY. I do not more then one heating zone.
Can any one explain the difference between a 2 stage and a modulating and which one may be more appropriate? These two furnaces were suggested by 2 different contractors. One recommended variable speed, one felt it was not necessary.
I am inclined to think modulating may be better but is it overkill for a small house?
01-25-2013, 05:36 AM #2
It(modulating) will provide the better comfort.
01-25-2013, 05:42 AM #3
Professional Member*
- Mar 2006
- The South
- 1,842
OP's biggest challenge is not brand, two stage, or modulating but being sized correctly for such a small zone.
IMO
01-25-2013, 06:13 AM #4
Goodman's 2 stage will time to high regardless of need. It can't use a 2 stage stat that will keep it on low. I'd want the modulating with the communicating control. Chances are your dealer will oversize, most do in a tiny house.
01-25-2013, 12:19 PM #5
- Jan 2013
- 7
I was under the impression the the modulating with the variable speed fan would give it the option to run between 25-100%. But I have a small, one level, one zone house. So you say the modulating will run on high all the time? So it will not operate as a two stage furnace?
Just very confused on all the terminology, and why two contractors have opposite opinions about whether I need a variable speed fan. Wouldn't the variable speed fan help with the central a/c unit?
01-25-2013, 01:09 PM #6
The AMH95 is a 2 stage but times to high after 0-16 minutes based on past cycles. So no long run cycles on gentle low in cold weather. Using the modulating furnace with the comunnicating stat, it will vary based on HOUSE NEEDS.
01-25-2013, 10:53 PM #7
- Jan 2013
- 7
01-25-2013, 11:07 PM #8
- May 2007
- DC Metro area
- 3,223
01-26-2013, 12:07 AM #9
- Jan 2013
- 7
Considering the estimates I've received, after rebates, have the Goodman modulating furnace coming out $200 cheaper then the 2 stage Amana. So it seems like getting more for less. I was just concerned if these features were beneficial or not considering my limited sized home.
So would a modulating furnace operate well in a drafty, lesser insulated house vs. a well insulated house?
