Results 1 to 13 of 15
Thread: Antivirus
    Breslau, Ontario
    Antivirus
    Hi Guys,
    Antivirus expires next month and would just like to see what everyone is using?.....I use ESET NOD32 right now along with Malwarebytes Anti-Malware.
    Apr 2010
    NYC
    avira
    make sure u hit I just want the free one,, otherwise u will get trial
    Customer is alWays opposite of Left
    Mar 2009
    Several Miles from Sane
    AVG2013 Free version and MalwareAntiBytes. After I saw 2 different IT guys running them I figured it must be OK. Never had a problem.
    If sense were so common everyone would have it !
    Any advice provided is worth exactly what you paid for it, not a penny more not, a penny less !!
    NY
    Microsoft's MSE has been good to me. And it's free!
    "Controls is a lifestyle not a job" -klrogers
    May 2002
    Baton Rouge, Louisiana
    Quote Originally Posted by dapper View Post
    I concur
    Quote Originally Posted by MatrixTransform View Post
    very soon it is you that will be pwned
    Mount Airy, MD
    Quote Originally Posted by Cagey57 View Post
    Amarillo by mornin'
    I use the MSE one on my work laptop also, and it has proven itself twice now. If we buy any AV we use Trend Micro. Works well, not a processor hog, and it's not a PITA to set up.
    I hate antivirus software. I haven't run an antivirus in over 10 years just because they are a huge resource hog.
    I keep a vmware image of an old XP computer I had years ago that I use to solely surf the web and mess around. If it gets infected, I delete it and fire up the original copy. Everything else I use for work only connects to control sites or absolutely trusted sites. With memory and storage being so cheap these days, there is no reason to not virtualize OS's. Try it, you'll love it.
    Desert Southwest
    Trend Micro on the work laptop and Bit Defender on the personal one at home using Windows 7 and Windows 8 respectively.
    If you can't fix it with JB Weld, Duct Tape, and Ty Wire it has to be replaced.
    No good deed goes unpunished.
    If you want to take off friday to go fishing then make sure you train your helper right.
    Jan 2003
    Quote Originally Posted by noskilltech View Post
    Ditto, I run bear back on most of my machines. I image every month or two and have custom scripts that zips up and FTPs important folders to a server every night. Something goes sideways, I restore the image and grab the current zip files and restore. I can get restored and be running in about an hour.
    Antivirus is almost useless these days. The exploits are put to use long before the virus definitions have them, leaving you totally unprotected.
    Personally the only scanner I trust to work is the Microsoft offline scanner. You burn it a CD / USB and boot to it. If the nasty is on your machine, it could very well have disabled (or otherwise hid itself) your antivirus. Booting to a known clean CD eliminates that hassle.
    http://windows.microsoft.com/en-US/w...fender-offline
    Again though. If its a new exploit, no virus scanner will have it until its found and documented.
    May 2008
    Southeast
    I've used AVG free version for a few years now and it's performed very well. I've used TrendMicro (paid) and Avira (free) in the past, and I was not satisfied. TM let some bugs in and Avira (free) is annoying. Also, they are both slow on scan compared to AVG. I've also seen MSE let bugs in that it could not clean.
    May 2008
    Southeast
    I also agree with a lot of what orion242 says, I'm just not as tech savvy as he is yet.
    Jan 2003
    Well I can save you some time, here’s what I use.
    Clonezilla - Good disk/partition imaging software. Works with windows network shares.
    http://clonezilla.org/
    7zip - Full function zipper with command line interface. CLI is a separate application.
    http://www.7-zip.org/download.html
    Filezilla - free FTP server, great client also
    http://filezilla-project.org/
    MS FTP - Plain windows standard command line FTP client. Commands can be fed to it via a .txt file.
    http://www.microsoft.com/resources/d....mspx?mfr=true
    I use the windows scheduler to run a custom .bat file that does some cleanup, zips select folders, then if a connection to the server is present it sends everything via ftp. Works on both XP and 7, 32/64 bit. I’m sure there are simpler ways, but it works well for me, very flexible, no software costs.
    At some point, if there is interest, I can comment and post my scripts.
