Results 1 to 13 of 15
    Feb 2011
    Georgia
    furnace burner???
    http://www.facebook.com/video/video....ideo_processed[/video]
    had this one last night. inlet pressure is 6.9 and outlet pressure is 3.45. i cleaned the burners but the only one dirty was the first one that is rolling back at start up. cleaned orifices. still has roll back at start up. i did notice when i was turning the furnace on and off to check it, that if i didnt let the inducer completely stop before turning it back on it wouldnt have roll out. what do yall think?
    Jun 2012
    Rising Sun, Maryland, United States
    did you inspect the heat exchanger?
    Virginia
    did you clean the pilot orafice ?
    its like the gas valve is opening too slow
    can you swap burners around ??
    Aug 2012
    check the amp draw on inducer fan motor.
    It's not if your doing it right it's whether your doing the right thing that is important.
    Feb 2011
    Georgia
    Amp draw was .9 name plate 1.7
    Oct 2011
    Toronto
    That is strange, make sure to share the outcome. Never know when youll come across something like this
    Feb 2011
    Georgia
    I do remember the valve took about 2 or 3seconds to get to 3.45. Is that normal or is it usually immediate
    Virginia
    I believe I heard they do make valves that are slow openers , i dont know enough about them to tell you anything , but if one got installed into that furnace on accident , it will act similar to what you are seeing
    If the pilot flame is Not big enough it could do that , or make a Whoosh sound
    Some are a real pain to diagnose
    Jul 2009
    Columbia, MD
    Delayed ignition. Check the runners on the burners. Make sure they are spaced enough. Was the valve replaced?
    Jul 2009
    Columbia, MD
    Let the furnace run for 5 minutes. Turn off gas valve, let flame go out, turn it right back on and see if it lights normal
    Virginia
    Quote Originally Posted by gravity View Post
    ahh .... you are bypassing the valve this way , checking to see if valve is opening too slow , good idea !
    Feb 2011
    Georgia
    valve was not replaced. it was original
    Feb 2011
    Georgia
    it will light normal because the inducer i still running. it lights normal when i cut the switch off and back on before the inducer has time to completely stop.
