Results 14 to 18 of 18
    Aug 2010
    West Monroe, LA
    The TH6220 does not have lock out ability. So either an outdoor stat must be added. Or you need to get a thermostat that has lock out ability.
    Do you use its set back feature? If so, don't, your costing yourself money if you do.
    There you go Beenthere found out that it was not able to do this so as he stated you have 2 options. New t-stat or outdoor sensor....
    I would go for the new t-stat personally but that's me. The question now is why do you feel that the lockout is set to high. Since the t-stat does not have the ability then something else might be going on with the system? Please post back!!!
    Yakima, WA
    Quote Originally Posted by ambergems View Post
    how can i disconnect the auxiliary heat? will it damage the system? I live in Pennsylvania and our winter is checking in at 14 degrees f... what do i need to look for when looking for an outdoor thermostat?
    Sorry to confuse... I would never suggest eliminating aux heat, just suggesting that someone ahead of you may have done that if your system is not keeping up.
    Aug 2010
    West Monroe, LA
    Quote Originally Posted by cjpwalker View Post
    Very good point. While I don't see often in my area anything is possible. To the OP how old is your system and have you always had a problem?
    Jan 2013
    The aux heat costs much more than the regular heat, and I personally would rather be a little more cold than spend exorbitant amounts of money for heat, which I am anyway because the aux heat was switching on when the thermostat was set at 60 degrees!
    Yes, we use the setback features in my house, I am very familiar with them.
    The major reason for my concern was that last year the heat was switched to EM heat for the entire month and we wound up paying $600 for that month. Last year was our first year with the heat pump, and nobody had the education to understand it fully. We rent and were given no manual or run down of instructions of do's, don'ts and how to's with the new unit. I understand oil and gas much better than this (crap). Plus my landlord had his cousin instal it - they are Vietnamese and don't speak much English and are often irritated when you don't understand them immediately.
    So you can understand why I didn't just get on the phone to ask them!
    So, as far as what everybody is saying,
    1.)I understand that my thermostat is not able to lock it out its self.
    2.)I need to have an outdoor thermometer on the pump its self to determine the lockout temperature.
    So my big question is this;
    how do I know what it is set at in the first place? How does the pump KNOW what the outdoor temperature is?
    I am sorry but most of the answers here are vague at best. I would like to know physically what I need to be seeing on the heat pump when I go outside to look at it. can anybody give me any ideas?
    Currently you have no lock out on your aux heaters. Set back should not be used on heat pumps with electric aux heat. Better to set it and forget it.
    Since its not your heat pump. You nee to have your landlord install a thermostat with out door sensor.
