Results 1 to 13 of 15
Thread: Amana Commerical Microwave
01-23-2013, 07:51 PM #1
Model# RCS- 10 YTS
115-120volts
Problem- everything functions except the microwave radiation effect
Obviously I called tech support and they ended up saying the magnatron was bag. Note; the unit was pulling 4-5 amps when the original magnatron was in and had it trying to microwave something but nothing.
The fan cuts on when the door opens and pulls about 0.4 amps but nothing anywhere else. So tech support said ohm the secondary to ground and it should have from 75-95 ohms and it had 85. Remember the fuse inside is fine. Tech support said of all that checks out then it's the magnatron which was under warranty. Got the new part, installed and still nothing. Tech support said it should be pulling around 14 amps at the transformer but nothing. Is there any advice I could get? Door switch works and things like like. It's a simple thing why does it have to be difficult. Thanks
01-23-2013, 09:14 PM #2
- Sep 2007
- British Columbia
- 12
Did you meter the capacitor? if it is good . get a megometer and check the high voltage diode...(rectifier) if bad replace. good luck Joseph....
01-24-2013, 07:59 AM #3
I checked the capacitor rated for 1.08 Uf and I got .80 uF
01-24-2013, 11:18 AM #4
- Sep 2007
- British Columbia
- 12
.80 is a little low ..Does this unit have a high voltage diode? it is on the output side of the cap to the frame of the microwave?...i would be looking at that...it only allows voltage one way..if it is going both ways(leaking) the mag will not work.....
01-24-2013, 11:37 AM #5
It does have one of those from the capacitor to ground, it's kind of insulated about 2 inchs long. How do you check it?
01-25-2013, 02:21 AM #6
- Oct 2008
- mid-Tennessee
- 254
I trusted a capacitor once that was a little out of tolerence and ended up on a wild goose chase. It ended up being the problem. With that reading, I'm sure Amana Comserv would tell you to replace it. As creeker66 suggested, a megometer (megohmmeter or megger) can be used to test the high voltage diode.
If you're certain the power transformer is getting its 120, has a good secondary winding (per the ohmmeter) and the magnetron is good, the cap & diode are suspect.
01-25-2013, 09:15 PM #7
Thanks ill check it out
01-28-2013, 02:20 PM #8
What do you guys think
01-28-2013, 02:22 PM #9
I used a different meter to check the uF rating on the 1.05 capacitor and it's reading 1.3uF
01-28-2013, 03:59 PM #10
trim your nails!
Total Energy Management, inc
01-28-2013, 04:36 PM #11
Everybody says that, they grow so fast! I need technical advice not grooming haha
02-05-2013, 07:34 PM #12
This microwave sucks
02-11-2013, 11:10 PM #13
