Results 1 to 13 of 15
    Richmond, Virginia
    Amana Commerical Microwave
    Model# RCS- 10 YTS
    115-120volts
    Problem- everything functions except the microwave radiation effect
    Obviously I called tech support and they ended up saying the magnatron was bag. Note; the unit was pulling 4-5 amps when the original magnatron was in and had it trying to microwave something but nothing.
    The fan cuts on when the door opens and pulls about 0.4 amps but nothing anywhere else. So tech support said ohm the secondary to ground and it should have from 75-95 ohms and it had 85. Remember the fuse inside is fine. Tech support said of all that checks out then it's the magnatron which was under warranty. Got the new part, installed and still nothing. Tech support said it should be pulling around 14 amps at the transformer but nothing. Is there any advice I could get? Door switch works and things like like. It's a simple thing why does it have to be difficult. Thanks
    British Columbia
    Did you meter the capacitor? if it is good . get a megometer and check the high voltage diode...(rectifier) if bad replace. good luck Joseph....
    Richmond, Virginia
    I checked the capacitor rated for 1.08 Uf and I got .80 uF
    British Columbia
    .80 is a little low ..Does this unit have a high voltage diode? it is on the output side of the cap to the frame of the microwave?...i would be looking at that...it only allows voltage one way..if it is going both ways(leaking) the mag will not work.....
    Richmond, Virginia
    It does have one of those from the capacitor to ground, it's kind of insulated about 2 inchs long. How do you check it?
    Oct 2008
    I trusted a capacitor once that was a little out of tolerence and ended up on a wild goose chase. It ended up being the problem. With that reading, I'm sure Amana Comserv would tell you to replace it. As creeker66 suggested, a megometer (megohmmeter or megger) can be used to test the high voltage diode.
    If you're certain the power transformer is getting its 120, has a good secondary winding (per the ohmmeter) and the magnetron is good, the cap & diode are suspect.
    Richmond, Virginia
    Thanks ill check it out
    Richmond, Virginia
    What do you guys think
    Richmond, Virginia
    I used a different meter to check the uF rating on the 1.05 capacitor and it's reading 1.3uF
    Apr 2011
    SE Washington
    trim your nails!
    Richmond, Virginia
    Everybody says that, they grow so fast! I need technical advice not grooming haha
    Richmond, Virginia
    This microwave sucks
    Jul 2012
    Everett, WA
    Have you checked the interlock switch? I had one on the ones that McDonalds uses do the same thing, and the interlock swich was having problems. It looked good and once I swapped it out to test the problem went away
    Quote Originally Posted by Joseph12345 View Post
    Model# RCS- 10 YTS
    115-120volts
