Results 1 to 13 of 14
    Lehighton, Pa.
    Furnace running non stop
    New app. 2500 Sp. ft. home in NE Pa. Infinity two stage 60,000 BTU propane furnace. Last night OD temps 6 deg. Indoor stat set to 71 deg. Furnace ran all night mostly in low stage, and periodically going to second stage. Is this normal with these cold temps?
    Aug 2012
    Yes, if you turned down to 68 you wuld save energy and it would cycle.
    It's not if your doing it right it's whether your doing the right thing that is important.
    Its working the way it is suppose to work.
    Tallahassee, FL
    Did you like the warm air continuously circulating rather than on and off?
    Sounds just what a 2 stage furnace should be doing.
    Sent from my HTC VLE_U using Tapatalk 2
    Rochester NY
    Wow, a properly sized piece of equipment! Hopefully we'll see more and more of this...
    May 2008
    Missouri
    As all posters have commented, it seems you've actually gotten a properly sized system!!! And it's working properly as designed. Yes, it will run longer cycles due to the multi-stage, however the 2nd stage (high) should only operate periodically. Sounds good!!
    Rochester NY
    ...Would you mind letting us know at what OD temps it cycles OFF instead of between stages?
    Lehighton, Pa.
    It is now 19 od, inside set to 72. It is cycling on and off and only running on low stage.
    Rochester NY
    THINGS THAT MAKE YOU GO "HMMMM". So here's something to think about. If you lived in an area where 19f was outdoor design temp, your furnace might be considered grossly over sized.
    72 seems a fairly warm ID setting. (it AIN'T just TEMPERATURE!) Is the relative humidity maybe a little low?
    Infinity has really awesome control of humidity. Do you have a humidifier on the furnace?
    Lehighton, Pa.
    We are retired seniors. In our younger days 65 was comfortable. No more. You'll see. One of the downsides of age, but consider the alternative. Yes we do have a bypass humidifier. Usually keep it around 38% but lowered it to the 25 with the colder od temps to prevent sweating of the windows. Once the coldsnap breaks, it will be raised again.
    Lehighton, Pa.
    Forgot to mention, Living area and master br have 12 ft. cathedral ceilings which obviously needs a lot of heat.
    Rochester NY
    Quote Originally Posted by jeepgrady View Post
    I feel ya, as I sit here with my cold kankles.
    Should be set and forget. I know commissioning is not part of resi lexicon, and that unit is so complicated even if they did give you the run through it can't all possibly stick.
    The Infinity should manage RH based upon outdoor temp. Let it do it's thing. If you see condensation occurring, adjust it back one notch (feedback to the machine that the house can't handle that RH curve).
    Think of it this way, computers calculate in split seconds data it would take you a life time to process. Communicating equipment is a very sophisticated computer you could never hope to match.
