Results 1 to 7 of 7
Thread: Wiring Diagrams
    Jul 2005
    Phoenix, AZ
    Wiring Diagrams
    What is the best way to learn wiring diagrams for RTU's, heat pumps or any other pieces of complex equipment? Just curious.
    Sent from my DROID RAZR using Tapatalk 2
    Phoenix,AZ
    Quote Originally Posted by phxhvac View Post
    Knowing the sequence of operation helps alot!!!
    Oct 2011
    Chicagoland Area
    Learn when it's not -10* outside
    Local 597 Service Fitter
    Metal Trade Journeyman
    PAY ME NOW OR PAY ME LATER
    It was working when I left...
    WWFD
    Dec 2012
    columbus, OH
    Quote Originally Posted by KB Cool View Post
    yep, if thiers a board or boards involved its the only way.
    Jan 2010
    Quote Originally Posted by 2sac View Post
    Yep...or only work on units where the diagram is on the service panel. Then take it inside (been there done that).
    Jul 2011
    Lehigh Valley, PA
    Start with small electrical sections. Work your way up. Clearly understand the high voltage whether it be three phase or single phase from the low voltage control circuits. Understand what each symbol stands for and how that part reacts in the circuit. i.e. Is this part some sort of switch that only sees one side of the circuit? Or is this a motor requiring both sides of the power? Look at 1p motor capacitor schematic wiring carefully and absorb. 3p motors will not require run or start caps. Look for wiring numbers on the wire itself matching the schematic.
    Hardest part for me, those darn schematics are too small and always faded.
    Mar 2009
    Mid-Mo
    Or outside if it's a freezer....
    Time time time time.
    First time you see it just get familiar with what does what, next thing you know it'll be all good.
