Results 14 to 26 of 33
    Jan 2010
    Quote Originally Posted by georgelass View Post
    The schematic said the heater was not on all units. But it didn't say it was optional on
    the units that had it. Because in my experience my assumptions have often coincided
    with screw-ups, I did not want to assume that the heater was optional for the furnace
    models that had them installed at the factory. Often what sounds logical to me
    usually has some loophole that I didn't consider. I try to be more cautious about
    winging it these days.
    Sounds like someone speaking from experience.
    Virginia
    I emailed you the install manual on this unit. It states the approx. temps the fan should turn "ON" and "OFF".
    Jan 2010
    Quote Originally Posted by rundawg View Post
    rundawg,
    Do you have any info on that heater type limit ?
    Thanks,
    VTP
    burlington county n.j.
    this was the last fan limit used on Lennox furnaces before they switched to blower control boards in the G20 furnaces.
    heater brought the fan on sooner than the normal fan setting in the control, more for efficiency than safety.
    Wrong terminology used here. It is not a heater for the LIMIT. Camstat was one of the mgf's. They had 6 wire controls and 4 wire controls. Lennox and DNP used them several years ago, before boards were common. 4 wire was fan only, 2 wires were 120 volt for blower, other 2 wires were 24 volt heat assist. When the burner came on the heat assist was energized and the small resistance wiring around the bimetal got warm and closed the switch before the furnace temp would. These especially good for an area that was cold and would pull in thru the return.. That would prevent any blower short cycling due to cold air over fan switch. The other control had 6 wires, the 4 mentioned above and 2 for the limit.
    Nov 2008
    Northern California, foothills.
    Quote Originally Posted by t527ed View Post
    Yep, that's what it looks like.
    Virginia
    rundawg,
    Sent you an email.
    Honeywell makes still makes that fan limit. L4064W. You'll have to go back and find out the insert length.
    Apr 2004
    MN
    If your supplier does not have the Honeywell, Camstat still makes them. I personally feel the Honeywell product is the better option though. I don't see any safety concerns with using a 4 wire F/L control without the heat assist. I say use what you have. As mentioned earlier, the customer may even be pleased with the warmer air coming out of the registers when the unit first starts.
    A Veteran is a person, who at some point in their life, wrote a blank check payable to the United States of America for payment up to and including their life.
    Gene Castagnetti-Director of the National Memorial Cemetery of the Pacific in Hawaii
    Ontario
    We called those "assured fan controls". As said they will bring the blower on quicker, and will maintain heat in the control through the run cycle so the blower will run a bit longer on shut-down and not recycle back on from residual heat. I recall a couple of furnaces that used them had drum style heat exchangers and the control was located where it would be very slow to pick up the heat when the burner was on no matter how finely you'd try to adjust the control, unless you used the "assured" control. You might wait several minutes for the blower to come on. Also one Lennox horizontal model in particular would trip on limit immediately after the blower came on if you didn't use the "assured" control. You can probably get away with not using the proper one without problems, but it's there for a reason. And I recall several times upgrading to an "assured" fan control as a way to solve nuisance cycling problems.
    Question authority!
    Quote Originally Posted by mike3 View Post
    thanks for clarifying it for me, too.
    I never had it explained like this and now I will look at it differently.
    Quote Originally Posted by jetstream View Post
    so does the assured control act like a sequencer when the call for heat is lost, in other words after X amount of time that portion of the control is open and now just residual heat activates the fan?
    if so, does it really help on the cool down or just for initial start for those cold short cycle instances?
    thanks.
    found this and answered my questions.
    http://www.honeywell.com/sites/servl...4-73BD77880C46
