Page 3 of 3 FirstFirst 123
Results 27 to 33 of 33
  1. #27
    Oct 2009
    new jersey
    Im old enough to have worked on that control 20 plus years ago. The purpose of the heater in the fan control is when you start up heat in morning with cold ra temp the fan control will cool off enough to stop fan.the heater keeps the fan on with a w call
  2. #28
    Nov 2008
    Northern California, foothills.
    After reading all of this, I'm left wondering how other furnaces using
    the more common, no-heater fan/limit don't have short-cycling on
    occasion. But it also makes it more clear why everybody now uses
    timed fan-on, fan-off.
  3. #29
    Salisbury, Maryland
    A pic of it would be great. At first I thought you were talking about one of the fan limits with an adjustable high limit, fan on and off tab that rotate when the HX gets warm but now I'm not sure. Either way, I'd do like T52 and check the temp at the limit and check your airflow. Its possible it could be bad but I'd confirm first because its not exactly common. You don't want to install a new one and have the same problem ya know.
  4. #30
    Salisbury, Maryland
    Nevermind, I didn't realize so many people had posted, and with pics....... lol Anyways, seems like alot of mobile home units with gas or oil use them. Some I've noticed get "hung up" when rotating and don't always turn blower on at right time. I'm guessing because someone in the past had screwed with the dial and got it out of whack?
  5. #31
    Nobody has mentioned energizing the tstat and have the blower come on after a few seconds when the gas is off. That is a sure indication there is a "heat assist" fan switch (control) installed.
  6. #32
    Nov 2001
    east kansas
    Most furnaces with these fan & limits are close to 20 years old and older. One should check the heat exchanger closely.
    Beware of advice given by some guy on the Internet.
  7. #33
    May 2011
    Western, KY
    Quote Originally Posted by ClimateCntlJohn View Post
    No that's just a really common failure on the fan/limit combos. They get weak over time from rotating and can't push through the set point or snap back through it(so the fan either won't come on or won't turn off), don't try to wd-40 or oil them because it doesn't help, the metal is just fatigued.
