Results 14 to 24 of 24
    Oct 2011
    Toronto
    Quote Originally Posted by 2141 View Post
    We are required to check every heat exchanger on every call no matter if it is a tune up or service call including a/c season at no extra charge.
    We do the same, its a liability - being the last licensed technician to service the appliance it becomes our responsibility to ensure its running safely.
    Kennesaw, Ga
    The Heat exchanger must be CHECKED!!!!
    Jun 2010
    San Diego Area
    just askin' how are you checking?
    Quote Originally Posted by chevster01 View Post
    Do you guys use a boroscope or just a mirror. What is your perfered method of checking?
    Jul 2012
    Cincinnati ohio
    Quote Originally Posted by webtrendjohn View Post
    Rigid see snake camera.
    Nov 2011
    St. Louis
    And how, exactly, are all of you checking the 90%'s?
    This outta be a hoot...
    Jul 2012
    Cincinnati ohio
    I don't really understand what you are asking. Whether it is a 80 or 90 I pull the blower housing and go from underneath on an 80 or check the secondary on a 90 for cleanliness or if it is a Bryant for corrosion. Also on 90% I remove the apex of the coil and put the camera in that way.
    Is that what you meant?
    Eugene, Oregon
    This is a good question. How many techs carry a snake camera? Are most techs just doing a visual inspection? How many are using combustion analyzers for a inspection?
    Also, what's the issue with Trane 90% furnaces? What section of the HX is having problems? Does it include American Standard?
    "The bitterness of poor quality remains long after the sweetness of low price is forgotten". --Benjamin Franklin
    "Don't argue with an idiot, they will drag you down to their level and beat you with experience". --Mark Twain
    http://www.campbellmechanical.com
    Apr 2012
    Cleveland
    I do visual, camera, and a ca. It all depends on the situation. I don't pull blowers and pull apart coils unless I suspect a problem based on the previous methods.
    Eugene, Oregon
    Quote Originally Posted by Hvac216 View Post
    What type of camera do you use? What's your method?
    Apr 2012
    Cleveland
    Quote Originally Posted by air1 View Post
    Dealt dct410. It's a 12v lithium ion. Has a spot for a micro sd card, and takes video and pics. The screen comes off so u can show the ho without carrying the whole thing around.
    Jul 2012
    Cincinnati ohio
    I posted a picture of the trane primary h/x crack a while back. It is underneath the entry of the flame where the metal is crimped. I will find the thread and bring it up to the top of the forum. The secondary h/x are just about always cracked as well.
