Results 1 to 13 of 16
    Jan 2013
    Why is my electric bill so high for my lakehouse? Electric heater? Using 2545 kwh
    Hi, I need some help. We just bought a lakehouse in MO and we spent 4-6 days out of 30 there last month. The refrigerator and a clock is on all of the time and the heater is set as low as it will go (~45) when we are not there. The first bill showed that we used 2545 Kwh of electricity and the bill was $188! We were there for 4 days! Could it be the heater? The home is an A-frame that's about 1000sq ft or less-it's just one big room with a loft. We have the vents closed in the loft. When we get there and turn up the heat (to 60 or 62) the house heats up within 3-5 minutes and shuts off and then runs periodically while we are there. We turn it down below 60 when we sleep - love it cold for snuggling ( I know...TMI.) Anyway...is it possible that we used up THAT MUCH electricity in such a short amount of time? What can we do to cut our bills? I tried to talk to the electric co about the high kwh, but he just said we needed to get used to it. huh? No TV, washer/dryer, internet, etc. is used.
    Tallahassee, FL
    If you have straight electric heat then yes that probably is normal.
    Moved thread to AOP Residential
    burlington county n.j.
    water heater or well pump?
    Quote Originally Posted by t527ed View Post
    Yep, A water heater with a leaking T&P can give you a big bill quick.
    Jan 2013
    Quote Originally Posted by cbeaumont View Post
    Yes, it's straight electric heat, no gas.
    Water heater - electric - whole house is electric, no gas.
    What's a T&P?
    We did have a water leak (drain from water heater - fixed this past weekend) and we had a malfunctioning waste grinder - also fixed - 2 weeks ago.
    do you shut the water heater off when not there? keeping water hot for a month in a cold house could be a big part of your bill.
    and what is the waste grinder? is it a garbage disposal under a sink or macerator pump for the whole house? if that was sticking on it could use a lot of electricity.
    Cincinnati, Oh
    you heat from 45 to 60 in 3-5 minutes?
    Either I call shananigans, or your equitment is GROSSLY oversized, and your running on straight electrics strips with no heat pump.
    All that other stuff you posted later isn't helping either.
    "Just get it done son."
    Dad adjusted
    Jan 2013
    Yes, we turn off the water supply and the water heater when we leave.
    Not sure what it's called, but it grinds the waste from the toilets after you flush.
    Call it what you want, hvacvegas, but it's true, the house heats up in less than 5 minutes. The house is like an efficiency apartment - when you walk in the front door, you are standing in the kitchen, the dining room and the living room at the same time. You can see the whole tiny place from that one door. As to your other comment: "All that other stuff you posted later isn't helping either.", if I knew that, then I wouldn't need to be on this website asking these questions now would I? Maybe your equipment isn't oversized and you don't have experience with this.
    Thanks for the polite responses from others.
    One thing is for sure the electric company is not on your side, you need to have your system checked by company, yes you have to pay for that but it might save you money in the long run.
    Tallahassee, FL
    If your heat comes from electric heat strips inside the air handler they can use 5kw to 10kw of electric per hour.
    Jan 2013
    I called the electric company again (thanks for the advice, toocoolforschool) and they said they agree something may be wrong. They are going to replace the meter and have the old one tested. I was also informed that if I have an outside outlet to shut it down when I am not there so that no one can use an extension cord and steal our electric (what!?); and that sometimes the meter is misread or mixed up with a neighbor. Since we have the smallest house that I can see for miles, that does make sense.
    I apologize for my lack of knowledge on the heat source in my house, SBKold, but I don't know if there are heat strips inside of the handler or not. I just see a heater in the closet and I know that there is a crazy amount of vents in such a small house, which I think is why the house heats up sp quickly. It is also insulated, which is unusual for an A-frame, I'm told.
    Jan 2013
    This is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise, commentary, or ask questions of the OP here. Please apply to the AOPC today, thank you.
