Results 14 to 26 of 34
    Jan 2013
    Quote Originally Posted by KB Cool View Post
    ebay has all the r-12 you need!
    You are correct with that!
    Jan 2013
    Yep thats what it was and "Failure to install new TXV will result in compressor failure"
    http://www.manitowocice.com/docs/upl...ns/8009663.pdf
    Yep, Have every book. And I just remembered that one. Options options options.... Way too many damn refrigerants out there...
    Dec 2012
    Illinois
    R409a is another R12 replacement.
    Pittsburgh
    Wasnt that HP80 in a small green can ? or was it HP81 ? I think HP 81 was 404a.....
    Dec 2008
    New York, ny
    I have a can of that expensive:banghead:
    Sent from my SGH-T999 using Tapatalk 2
    Oct 2011
    Chicagoland Area
    HP 80 was in the small green can
    Oct 2009
    Raleigh, NC
    15 inch vacuum on evap? Doesn't anyone think that he has a TXV problem first and foremost? It probably has a full charge.
    Jul 2000
    Cuenca EC
    HP81 (R402B) is in a 13 lb cylinder and its ASHRAE designated color is Green-Brown/Olive.
    Check out Icemeister's Back Room
    Read My Latest Rambling:
    What Is Mechanical Subcooling?
    ...and a new calculator:
    Nitrogen Pressure Calculator
    Oct 2011
    Chicagoland Area
    Your right, I'm wrong
    Jul 2000
    Cuenca EC
    Quote Originally Posted by MicahWes View Post
    Manitowoc machines from that era used Alco TXV's with steel powerheads...which were notorious for rusting through and causing a dead valve. The replacement valves had stainless steel powerheads.
    Aug 2001
    HP81 replaced 502 in Manitowoc ice machines. Dupont MP39 for R12 AND CHANGE txv
    Feb 2012
    Who still has original R-502 Ice Machines?!
    Oct 2011
    Chicagoland Area
    Quote Originally Posted by MechanicallyInclined View Post
    I've got one. I recently replaced a txv in a Hoshi at the national headquarters of a nationwide retailer. Put fresh 502 back in it.
