Page 2 of 16 FirstFirst 12345678912 ... LastLast
Results 14 to 26 of 196
Thread: THPRE
    Quote Originally Posted by hvacvegas View Post
    I offer 3-1 odds that the indoor coil is incorrect, even if it's a "match".
    A 2 R instead of a 3 R.
    Cincinnati, Oh
    yep, exact situation that we discussed in the past, is what I'm thinking.
    "Just get it done son."
    Dad adjusted
    Tallahassee, FL
    Did you use origional blower motor that came with trailer and just replace the coil that sits on top?
    Did the goodman techline guy ask about static regain collar? Basically that pertains to their one piece airhandlers and acts as an extension of the blower outlet. Personally I haven't seen goodman publish data about regain.
    A compensator holds (stores) refrigerant inside during heat and releases it back in cool. Recievers aren't typically used in residential and I don't believe they are used with heat pumps (i could be wrong) .
    Cincinnati, Oh
    Quote Originally Posted by SBKold View Post
    Goodman's been back and forth with receiver/accumulators. I do not believe the 2010 model has either.
    Dad adjusted
    Tallahassee, FL
    i know some people called what you are referring to a reciever but its truly a compensator.
    Very different operation. But Kinda the same!
    Jan 2013
    TRAIL,OREGON
    I will get the numbers tonight. Sounds as though some of you are knowledgeable enough to know what kind of a "match" was sold to me. Thanks for the reply , THPRE
    Jan 2013
    TRAIL,OREGON
    I used the whole air handler from Goodman. It does have a variable speed blower. The old one was just a single speed electric heater. The goodman people did not ask about a regain collar , it was just mentioned elsewhere and I was not familiar with the term. When we have the telephone consultation on friday I want to be as knowlegable as possible. My installer is a customer/freind of mine but he has no idea of what to do. The house is made in three sections and each section has a main trunk duct with branches to the registers. Originally it had just one connector between the trunks. Now we have three 16 inch soft ducts ,one to each trunk duct . This made the air flow acceptable. Thanks,THPRE
    Jan 2013
    TRAIL,OREGON
    We have recievers in the automotive business as well as acumulators- these I understand. Compensators ofcourse are not found in automobiles. How do you get around using a compensator without making the two coils the same capacity? Thanks for the answer , THPRE
    Cincinnati, Oh
    Quote Originally Posted by THPRE View Post
    That is way too technical for this area of the forums. We can provide general advice, but we don't delve into extremely technical issues.
    Get your model numbers, then get back with us.
    What I will tell you, is that the symptom your having is not uncommon, but I would suggest an individual who specializes in goodman equipment, as they will have ran into this before.
    Do not find one who specializes in New homes.
    Find one who regularly installs AND services goodman equipment.
    By the way, I've installed Goodman/Amana for 8 years, and never heard of a "static regain collar".
    Where have you heard this term?
    I'm going to guess from someone on the engineering side.
    Which means he's overthinking this.
    Dad adjusted
    Tallahassee, FL
    What is the return side like?
    Take some pics for us.
    I don't think they had any 2 row coil matches for a 4 ton unit.
    You say its variable speed I wonder if its simply not wired right. Get us those numbers.
    Virginia
    airflow airflow airflow
    Go Trump
    Jan 2013
    TRAIL,OREGON
    Good morning , the Goodman numbers are as follows
    heat pump -- model # ssz160u81ac
    -- serial # 1001013387
    blower / air handler -- model # mbvc2000aa1aa
    -- serial # 1005641465
    coil --- model # capf4860d6ba
    --- serial # 0912735419
    I do not know if you are familiar with Proctor Engineering Group's "check me " program or if it just a west coast thing but I have a certificate saying that the air conditioner part of the system is working correctly with proper unit sizing and proper air flow and acceceptable numbers for duct leakage as well as good number for home air leakage. Thanks,THPRE
    Jan 2013
    TRAIL,OREGON
    Whops - forgot to say that the line set size is copper 3/8 on small tube and 3/4 on large tube. This exactly matches the size of the tubes coming out of the heatpump. Line set is probably 12 feet long.
