Page 12 of 16 FirstFirst ... 25678910111213141516 LastLast
Results 144 to 156 of 196
Thread: THPRE
  1. #144
    Jan 2013
    TRAIL,OREGON
    SO WHAT DOES THAT MEAN? YOU HAVE THE NUMBER CORRECT. WHAT I HAVE IS A COPY OF A FAXED CERTIFICATE. COULD THEY HAVE CHANGED SOMETHING AFTER SENDING THIS COPY? AT THE BOTTOM THERE IS A CERTIFICATE NUMBER - HARD TO READ AND A MILE LONG. 129246540081061465 MAYBE. I CAN'T REALLY READ IT. AND IT MAY NOT COUNT ANYWAY. DATE WAS 7/26/2010. THANKS
  2. #145
    Jan 2013
    TRAIL,OREGON
    I TRIED AND COULD NOT VERIFY IT EITHER BUT I DO NOT KNOW ALL THE ANSWERS SO IT MAY NOT COUNT.
  3. #146
    Aug 2012
    Quote Originally Posted by crmont View Post
    Sheesh dude we are here to help if we can. Thats uncalled for IMO.
    I not being mean just calling them like I see them besides he's yelling at everybody. I commend you for your efforts, how many times can you tell a brick wall to move?
    Certified parts changer.
  4. #147
    Aug 2012
    Oh and not to mention 147 posts and three txv's later.
  5. #148
    Jan 2013
    TRAIL,OREGON
    YEAH TOOCOOL I HAVE CAP LOCKS ON ALL DAY ON MY WORK ORDERS AND SOMETIMES I AM TOO BUSY OR TOO LAZY TO TAKE THEM OFF. BUT THANKS A LOT FOR YOUR help.
    THPRE
  6. #149
    Aug 2012
    TOO LAZY you called it. WoW ThAt'S HaRd.
  7. #150
    Jul 2009
    South Carolina
    I would get someone with an anemometer to measure the return air velocity. It's not the most accurate way of checking air flow but its fast & easy & would give you a ball park idea of how much air you're really moving..
    Gary
    http://www.oceanhvac.com
    An engineer designs what he would never work on.
    A technician works on what he would never design.
  8. #151
    Aug 2012
    Quote Originally Posted by garyed View Post
    Although this is great advice there will be no attemp to correct the problems on this system only more drawn out dribble.
  9. #152
    Jan 2013
    TRAIL,OREGON
    TOOCOOL -WHO DID NOT DO WELL IN SCHOOL- YOUR ANSWERS HAVE BEEN THE LEAST INFORMATIVE AND YOUR SUPPOSITIONS ARE ALL WRONG. AN EASY CURE IS TO JUST GO AWAY. THANKS THPRE. To the rest of you thanks for your thoughts and opinions and thanks for educating me. I think I need to wait untill I get some response from Goodman. CRMONT - special thanks to you , you dug in and asked intelligent questions. Gary, I may try your suggestion but every time I tried to talk cfm or velocity all the pros figuratively looked down their noses at me and said "we don't care about cfm,only static pressures". Thanks for the help! Don't worry TOOCOOL there is always welfare!
  10. #153
    Jul 2009
    South Carolina
    Static pressure is always good to know but it doesn't help determine CFM when you're dealing with a variable speed motor. Unless the static is above the threshold usually around .8 to 1.0, the motor is designed to push whatever CFM it is set up for. Maybe you could get a referral from a Goodman distributor in your area for one of their dealers that is familiar with that system. A lot of distributors have their own field tech reps that will go to the site when one of their dealers gets stuck on a problem.
    Gary
  11. #154
    Jun 2006
    Richmond, VA
    Absolutely wrong.....static pressure when properly measured and compared to manufacturer's data has nothing to do whether is a variable speed motor or not!!!!! It may "push" a close cfm at .9 static but its still WRONG.
    It's not the Brand with the fewest repairs-It's all in the install!!! Attention to detail and using the best materials!
  12. #155
    Lancaster PA
    Ok, so how would you know what the static is unless you took a static pressure reading.
    It does also tell you if your going to be able to use a higher MERV filter or not.
  13. #156
    Jan 2013
    TRAIL,OREGON
    Goodman says they have no field rep. in this area. I have been waiting 6 days since giving them the numbers they wanted. Called my installer today - he called them -- we are still waiting. "All good things come to he who waits". I hope. Thanks THPRE
