Results 1 to 9 of 9
    Feb 2007
    Ohio
    Belt drive pulley / fan...
    Well yes I'm still fixing up old belt drive refrigeration units, that should tell you a little about me and my customers. Anyhow I'm in need of a 4" double pulley with fan on it and having a 7/8" shaft bore. Can't find anything anywhere Any suggestions besides sell em a new unit ?
    Thanks in advance
    Joe S.
    you talked to Grainger ?
    Jul 2012
    Western KY
    Pulley or sheave?
    Dec 2008
    New York, ny
    How big is the fan?? How many blades what degree which way? I can ask at my local guy here he has a whole bunch of old stuff
    Sent from my SGH-T999 using Tapatalk 2
    Pittsburgh
    A good machine shop should be able to help you, I have run into this in the past and that was only solution I could do. Be fore warned it wont be cheap.
    Jul 2012
    Western KY
    Da. "With a fan on it".
    Jul 2012
    Western KY
    Tri state bearing is pretty good at matching just about anything up, in our area anyway.
    Feb 2007
    Ohio
    Thank you for all the reply, I will get some spec's on later as to dimensions. I thought the same as " Coolerguy", National machine is in the area and some smaller shops. I have the original which has a 3/4" bore and a jig mill should do the job. My motor replacement has a 7/8" shaft with no fan on the sheave / pulley. Bore it out and cut a new keyway to the 7/8" dimension seems the way to go.
    Joe S.
    Feb 2007
    Ohio
    Thats probably what I'll get, da whats the fan for...?
