    Feb 2013
    ClimateRight Heat/AC Replacement
    Greetings all, This is my first post.
    I currently own a ClimateRight (CR-2550) http://www.climaterightair.com/cr-2550. It is just not powerful enough. I need the heating capacity of the more powerful CR-7000 (cooling=7000BTU/heating=7500BTU) http://www.climaterightair.com/cr-7000, but this model does not have the auto switching controller I need. It has both modes but has to be manually pressed for heating or cooling.
    So I guess my first question would be...would i be able to install my own controller (relatively easily) in the more powerful model?
    Second and more prefferably...Are there other units that meet this heating/cooling capacity requirement and also have inlet and outlet ports to connect vents to?
    Operation requiremtents:
    -unit can only be outside
    -can only connect to room via 6'' (approximate) diameter duct
    I know this might be in the wrong Topic. maybe needs to be in controls section??? but any help would be much appreciated as I need to source something soon.
    Thanks for all your help and I am sure glad there is a website dedicated to this stuff!
    Adam
    SW FL
    Quote Originally Posted by acommons View Post
    Second and more preferably...
    Operation requirements:
    Adam
    Why does the unit Have to be ONLY outside?
    What's the area and function of the space being Heat/Cooled?
    http://www.grainger.com/Grainger/DAY...&cm_vc=IDPTSZ2
    Alternate: Danby DPAC10061 Portable Air Conditioner
    Designer Dan
    Feb 2013
    Maybe I wasnt clear in my first post.....
    I was just wondering if there was a unit with similar heating/cooling capacity as the climateright cr7000 that had auto heating cooling mode where it would regulate temperature whether or not it was hotter or colder than the temp of the controlled environment.
    It needs to be a single unit and have inlet and outlet vents similar to the climateright model.
