Page 3 of 3 FirstFirst 123
Results 27 to 39 of 39
  1. #27
    Jul 2012
    Western KY
    Quote Originally Posted by Gib's Son View Post
    Flip the caster 180, stick in a new bearing, dimple the shaft a few thousand times to overcome loss of metal due to rubbing.....good to go.
    Cradle bearing. I like it.
  2. #28
    May 2012
    Upper Michigan
    Lucky the race was still on the shaft and saved it anyways.
  3. #29
    Dec 2012
    Spokane, Washington
    That's how they got the idea for rotozip
  4. #30
    So how many times did someone replace belts before anyone looked at the other end of the air handler?
  5. #31
    Mar 2009
    Mid-Mo
    It's about time you get back on here!
    Around here where I work it's pretty likely to see a grease tube break, bearing fail, then go "this thing didn't get greased" even though there's a turd in the bottom of the air handler.
  6. #32
    Hmm guess the shaft was not cold rolled steel haha it showed that unit who's boss!
  7. #33
    Jul 2000
    Northern Wisconsin
    Yeah......... BUT!....... it only made noise when it ran.
  8. #34
    Sep 2006
    Burnaby, BC
    Those Trane shafts are heavy!!
    IIRC, they're 3" diameter solid steel and turned down to 1-7/16" on the end for the bearings. Won't be fun to change the shaft, assuming the fan wheels are okay along with the blower housings.
    A hint on the bearings from experience; The bolt spacing on the flange bearings that Trane uses are non standard. Make sure you get them from Trane or you'll be out of luck when you go to replace them and find the bolt holes don't match.
    Sent from my iPad by carrier pigeon
    I do three kinds of work.
    1 - Good - 2 - Fast - 3 - Cheap
    Pick two
  9. #35
    Vancouver, British Columbia
    LOL. looks normal to me.
    If a day went by without a problem - there'ld be a problem.
  10. #36
    LOL. was it noisy?
  11. #37
    Quote Originally Posted by karl k View Post
    The ones I've worked on had a hollow shaft, like a drive shaft on a car.
    Still not something I like wrestling with over head, off a ladder.
    I've never had a problem finding bearings for Trane air handlers at a bearing and pulley supply house.
  12. #38
    May 2012
    Upper Michigan
    Being my first day at that point I showed up with a bearing they gave me, it had a wider bolt pattern but a drill took care of that. The shaft was hollow but there was only 8" wide panel up top to access it so I had to crib it up higher and higher til it was in the right spot.
  13. #39
    Dec 2009
    Very cool never seen that one happen
