Results 14 to 26 of 39
    Sep 2012
    Central Florida
    It's pics like this that make me question trying to go from manufacturing these to service. Much easier to install bearings and shafts when the unit is new, only half assembled and sitting on the floor.
    May 2012
    Upper Michigan
    The shaft was 5" diameter but hollow I'm sure, it was pretty heavy still. The blower cage looked the same, and it had zero fins on that wheel also, it was pretty messed up.
    Mar 2009
    Mid-Mo
    Sounds like it's gonna take a crew to get things out and back in if its that high in the air. Should be fun!
    May 2012
    Upper Michigan
    We put it together to get heat going, store was pretty cold, there going to run it since there shutting down in 2 months
    Mar 2009
    Mid-Mo
    Hope it makes it....
    May 2012
    Upper Michigan
    It should I hope, if not I have 2 electric space heaters they can borrow!
    Southern California
    Only half the bearing failed.
    Remove the 2 bolts, raise the shaft up & rotate bearing 180 degrees & replace the bolts.
    Voila!
    Another 5 years of service.
    Always drink upstream from the herd
    Okieville
    That was one tough v-belt
    Quoted by "Coolerinfrederick"
    Performance based pay sucks, and at the end, the cust. gets screwed, if i'm on the clock i'm getting paid regardless of what i'm doing.
    Nov 2011
    Long Island, NY
    Just give it a little WD-40, it'll be fine
    Oct 2009
    First job for the new company was fixing this lolAttachment 348501
    Dam belt is loose again.
    Never argue with a crazy man.
    Jan 2013
    Champaign Illinois
    Nothin some duct tape can't fix
    Nov 2001
    Seattle, WA
    I had to look at that twice before I realized that was the shaft that had worked it's way down through the base metal. Never seen one do that.
    I have a church with 50 year old Trane air handlers that wore the bearing through. Even though everything was working except the shaft and bearing they chose to replace the entire 1,000 pound air handler. Then they found out the ceiling below it was abestos so they had to spend a few thousand more on removal even before the old air handler could be lowered out of the ceiling for replacement.
    - Alexis de Toqueville, 1835
    Boise, ID
    Flip the caster 180, stick in a new bearing, dimple the shaft a few thousand times to overcome loss of metal due to rubbing.....good to go.
    If a nation expects to be ignorant and free, in a state of civilization, it expects what will never be. (Thomas Jefferson 1816)
