Results 1 to 13 of 14
Thread: Fuel cost calculations?
01-20-2013, 10:08 AM #1
- Jan 2013
- 12
Can someone tell me how to do the calculations? I have a 14.5 seer heatpump with an 80 percent efficent oil furnace. I have been wondering the same thing but don't know how to do the numbers. I suspect my number to be much lower since oil is high and my furnace is not as efficent.
01-20-2013, 10:16 AM #2
Started a new thread for you.
01-20-2013, 11:04 AM #3
- Jun 2001
- Oklahoma City
- 2,578
01-20-2013, 12:28 PM #4
Professional Member*
- Mar 2006
- The South
- 1,841
If you provide your all inclusive electric rate by cost/KWH, COP preferred or even HSPF eff rating of your HP, and cost/gal of fuel oil, I can give you a good estimate to be used as a guide only.
IMO
01-20-2013, 12:36 PM #5
- Jan 2013
- 12
It looks like I have a cop of 3.64@47F and 2.6@17F for my furnace and ecoil. I'm paying about $3.80 a gallon for oil for my 80% efficent furnace and if I read my electric bill correct I'm paying $.12 per kwh. It seems there are a lot of variables from what I have read including house and ducting insulation that factor in?
What I am really interested in is the economic balance point at this time. I doubt I would want to run the heat pump when it's below 25F outside regardless of the economics just for comfort reasons alone but just trying to get an idea if its worth running it that low from a $$ standpoint?
I'm sorry if this is a duplicate of similar posts but I tried to read some of the existing posts on the subject and didn't totally understand some of the termanology.
01-20-2013, 12:43 PM #6
- Jan 2013
- 12
If it makes a difference I will also add that I only have a single speed blower on my forced air system.
01-20-2013, 01:00 PM #7
- Jun 2001
- Oklahoma City
- 2,578
01-20-2013, 01:15 PM #8
- Jan 2013
- 12
Thanks, if that turns out to be the case the new heat pump will probably save me over $1,500 per year and that doesn't included the savings in the summer months over my 10 seer air conditioner I replaced with the heat pump.
01-20-2013, 02:01 PM #9
- Mar 2006
- The South
- 1,841
KKrace
While you don't provide the size of your heat pump and oil furnace, you should run the heat pump as low as possible as long as you are comfortable and heat pump heat Is able to maintain your inside thermostat setting. Once inside temperature begins to drop, that is the point that you should set your changeover from HP to oil furnace. Keep in mind your furnace will come on to temper the air during a HP defrost call unless this function has been disabled.
Here are the numbers from a fuel comparison calculator that I like to use as a guide only. I decided to use a 3 COP as an average.
Cost per 100,000 btu of useable heat
Electric baseboard: $3.16
Heat pump: $1.17
Oil: $3.44
You can readily see that the savings when using heat pump heat are significant. Hope this helps.
IMO
01-20-2013, 02:21 PM #10
- Jan 2013
- 12
01-20-2013, 02:26 PM #11
- Jan 2013
- 12
I just looked at an online calculator and compared the price per BTU for my 80 percent eff oil furnace vs electric resistance heating and at the prices I'm paying they come out very close. Does this mean I could heat my house on electric baseboard heaters for the same cost as my oil furnace?
I always thought resistance heating was the most expensive method to heat a house?
01-20-2013, 02:32 PM #12
- Jan 2013
- 12
Thanks again for all the replys. I made another post in this section on a different subject regarding my heat pump freezing up titled "heat pump iced up/ interesting problem hybrid problem w/oil burner"
Over 120 have read it but no replys yet. If anyone has any thoughts I'd like to here them.
01-20-2013, 04:05 PM #13
- Mar 2006
- The South
- 1,841
Your BTUs on your fuel oil furnace will remain constant when compared to heat pump heat BTUs that drops as outside temp drops.
And yes, electric resistance heat on a BTU basis is cheaper than oil heat by close to 10%. of course this varies with your cost of fuel oil. My fuel comparison calculator while close is to be used a guide only.
Was the addition of the HP installation by a qualified and licensed HVAC dealer?
IMO
