    Jan 2013
    Confused Volume Damper Design
    Hello people;
    first, i have spent some time trying to figure out which forum to post my question at, and i hope this is correct. Please remove it in case i was wrong. i hate breaking the rules
    Well, i'm working on a project of manufacturing an in-house volume control dampers, i'm working on the design now and it's almost done.
    However, i'm still stuck at some points without any answers:
    1- how to decide proper number of blades ? (in case of having diffrent widths, e.g.: either 5 blades of 4" or 4 blades of 5")
    2- how to decide where to place the extended shaft or the manual handle, top balde or center or bottom ? based on what.
    Thanx in advanced guys.
    You should probably go to an engineering forum. Try http://www.eng-tips.com I'd go the route of the least blades in the airflow and for the handle mounting location, I have seen them positioned in the middle and top or bottom. I doesn't really make a difference to me
    Jan 2013
    Thanx Vinster, i'll give it a shot.
    Apr 2011
    Coastal Maine
    Another option is www.physicsforums.com. They have a Mechanical Engineering section in there.
    Simpler is better. Do use all a favor and keep in the back of your mind, the poor technician that will one day have to replace the actuator or the connecting rod.
    Good Luck
    Jan 2013
    cool website , meplumber !
    thanx again
