Results 1 to 13 of 14
    Vacuum pump oil.
    Would like to hear how often guys change the vacuum pump oil?
    RYJ advise after every evacuation, but seems like that is a CYA from them for warranty issues.
    In reality, what giudes are used when to change it?
    Seems a waste to change if you have a clean system and do a few jobs.
    Of course, should it become contaminated, that would be a no brainer.
    Aug 2001
    Pavilion, NY
    I know all what everyone says,,, change it each and every time and twice on Sundays,,,,,,,I change mine when I have a hard time pulling down to 500. I would guess I average about a dozen Evacs per change.
    Tallahassee, FL
    I found out quick you change it right after evac of a acidic system. My pump turned nasty cause it sat after this.
    Then again for good measure.
    Nov 2011
    East Side
    for best results, and long vacuum pump life, it should be changed after each use. don't forget those contaminates, acid, moisture, etc. also will damage your pump over time.
    that said, I change mine about every 2 or 3 uses.....unless I use it on a large system where it's running for a few hours, then it gets changed after that use.
    Quote Originally Posted by 71CHOPS View Post
    Thanks, I guess it´s what I e`xpected to hear. Basically use your common sense. Better stock up then!
    May 2011
    Western, KY
    Any compressor failure I change it immediately after evac, the oil flows better and you get more out when it's hot. On new units with new linesets I'll do 4-6 and change the oil.
    Make sure you're using a micron gauge, if it's taking longer to get down below 500, change the oil even if it's been all new units.
    Feb 2012
    Durham, NC
    I use an Appion TEZ8 vacuum pump, makes for very easy changes. I carry 3 containers of fresh synthetic vacuum oil each time I need the pump. Sometimes I change the oil during evacuation if its pulling too slow.
    Athens, Ohio
    Ditto for the Appion TEZ8. Oil changes are quick. The quantity of oil is less. And the evacuation is more efficient.
    Thanks a lot for all the feedback, it has helped give me some good guidlines of what people do.
    Just one last question. I have a RJY Super evac and supplied with its own oil.
    Is it OK to use any vacuum pump oil as there are many and different costs.
    As long as it is of the right specification it should be fine as long as it is a recognised one.
    Apogies for bumping this, only other choice was a new thread which might not be appreciated.
    Any feedback on the below?
    [B]"Just one last question. I have a RJY Super evac and supplied with its own oil.
    As long as it is of the right specification it should be fine as long as it is a recognised one".
    Jan 2013
    How many Robinair pump owners pour oil directly into the pump intake as it is running to flush old oil out?
    Jul 2005
    Quote Originally Posted by Itstony View Post
    I buy whatever they have on the shelf. Never had any issues. As far a "when to change the oil", bleed a little oil out and check for water and discoloration. If you see water and/or discoloration change the oil. If the oil still looks good, then connect your micron gauge directly to the pump and see how low it'll pull. According to something I read somewhere a good pump should pull a minimum of 50 microns on itself. If it won't, then you either need to change the oil or a buy a new pump, whichever the case may be.
    The rate at which a pump will pull down a system is directly related to how low the pump will go. For instance, a pump that will only pull 500 microns minimum on itself would take literally forever to pull 500 microns on a system. So logic dictates that the lower it'll go, the quicker it'll evacuate a system.
    I don't change the oil after every use. That's ridiculous IMO. My current vacuum pump is 4 years old at least and will still pull less than 30 microns on itself in nothing flat with used oil in it. Just checked it last week and BTW it still has that used oil in it. When I change the oil again, which will probably be next week sometime due to the mild weather and spare time we'll have, I'll recheck it.
    Thanks hvacrmedic, good reply and advice.
