Results 27 to 39 of 46
  1. #27
    Rochester, NY, USA
    Quote Originally Posted by zman420 View Post
    its a factory nitro charge from a 4 ton condensor,i do not know how but it did ,and hopefully and i said hope fully running for the short time that i did will not harm the unit
    25-27 years in the business and you post this
    i started unit with my new skills i learned on the job
    Now we might infer from that statement that you were either inexperienced or had no idea what you were doing.
    I know it sounds like we're a bunch of smart asses, but you can see from your post how that might come across.
    Good luck with that unit
    Measure Twice
    CUT ONCE
    Crap, throw that away and get a beer
  2. #28
    Caledonia WI
    ok ill do thanks ,,i came to ask questions and learn ,not to be subjected to comments that are not helpful.
    You have to expect a fair amount of ribbing as you climb the ladder. Everyone here I'm sure got plenty, I know I did especially since when started I was working with my older brother. Look at it this way, you're learning and providing us entertainment at the same time
  3. #29
    Tallahassee, FL
    I cant stop singing--
    WHAT.......WOULD .......fengmaster do.....
    Heat pump.......no heat
    How'd it get that way?????what do I press?????
  4. #30
    Rochester, NY, USA
    Quote Originally Posted by SBKold View Post
    I was wondering why my dog started whining
    Measure Twice
    CUT ONCE
  5. #31
    Tallahassee, FL
    Cant be. He must have to pee.
  6. #32
    Rochester, NY, USA
    Measure Twice
    CUT ONCE
  7. #33
    Feb 2011
    ok fare enough ill take it and when i have time and sit down and type and ill explain my experiance and why i wrote what i did
    cheers genuises!!
  8. #34
    First of all, I don't think that running a system with a mixture of DRY nitrogen and R-22 or any other refrigerant for a few hours or even a few days will cause a noticeable reduction in the lifespan of that unit.
    I've seen systems operate with air in them for a substantial period of time (given the number of calls before the problem was found and fixed) with no loss of reliability after the problem was corrected.
    As has been said already, recover the contaminated refrigerant from the system and pull a deep vacuum on the system.
    There IS a way to easily and safely re-use that contaminated refrigerant, though. I won't go into it in the open forum, but I've done it a few times and have never had a problem with it.
  9. #35
    Palmyra, Missouri, United States
    Quote Originally Posted by Hvac216 View Post
    With 420 in the username it is probably easy to forget something like that.
    lol
  10. #36
    couple of our installers did the same to couple different systems. went back on them head pressure bouncing around like a bull in a china shop. reclaim evacuate recharge all good. keep your head up zman, keep learning, you will never stop. the guys that did it at our shop have 15 plus years they just dont read.
  11. #37
    Jul 2010
    nebraska
    Guaranteed you're not the first or last guy to do that.
  12. #38
    Feb 2012
    Durham, NC
    I was really cornfused as to why you were doing an AC start up in January, but being in FL explains alot If you forgot to open the service valves, wouldn't the unit be bouncing off the HPS? If the system is not equipped with an HPS you could have done some major damage to just about every component in the condenser.
    Good luck man, pull a 500 micron vacuum and get your subcool right and you should be squared away.
    PS: This thread is awesome
  13. #39
    British Columbia, Canada
    Yup. Agree on all points.
