    Apr 2003
    Niagara Ax- Anyone have a rate limiter block?
    I need to limit a percentage output over time. The spyder has a rate limiter that works and is exactly what i need. If only i can come up with something similar in a jace. I have had no luck so far. Anyone have any ideas or something that works?
    Melbourne
    could write a program object i spose...I would myself but a little busy atm
    http://www.mathworks.com.au/help/sim...telimiter.html
    1 + 1 = 3 ( *** for very large values of 1)
    Be brave. You cannot get eaten by an imaginary tiger.
    Apr 2003
    I need to learn a little more about writing custom blocks. My skills are not up to par to write my own yet.
    Jun 2009
    StL, MO
    A LoopPoint module can be made to work. Link the output you wish to limit to the LoopPoint Setpoint slot. Link the LoopPoint Output to LoopPoint Controlled Variable. LoopPoint Output is the limited output. Set LoopPoint Loop Action to Reverse. Try 0.5 proportional and 10.0 integral to start.
    UA LU 562
    Melbourne
    Quote Originally Posted by DaveCR View Post
    yep, good solution ... integral action is exactly a rate limiter
