Results 1 to 9 of 9
    Dec 2008
    New York, ny
    They clean the units all the time. Really?
    3 hrs of cleaning and still dirty.
    Sent from my SGH-T999 using Tapatalk 2
    Jan 2010
    Is that a PTAC ?
    Dec 2008
    New York, ny
    Ductless split.. Fujitsu 24k
    Los Angeles
    looks like it was in a fire and the unit kept running, taking in all the soot.
    Dec 2008
    New York, ny
    I think its oil. They where near a kitchen and maybe there hood wasn't working correctly and took in sound oil.
    May 2011
    Oklahoma
    I thought fire too.
    Why even try to clean it?!
    Dec 2012
    Spokane, Washington
    Mini splits in kitchens are not a good idea, even if you clean them alot. Sooner that later something WILL break. To much humidity and oil to be practical. Yours is the perfect case though, better roll up your sleeves for that one!
    Dec 2008
    New York, ny
    Anything in the kitchen is a bad idea.. unless you do a nice fresh air setup which most people Dont opt for. Restaurants most of them so what's the cheapest and will work, for the time being.
    Dec 2012
    Spokane, Washington
    If you're looking for "cheap" up front, then just keep doing what you're doing. I would check to make sure the exhaust fans and make up air are balanced (clean too) first. Most places like that have a design flaw such as no MUA, not enough exhaust, other equipment added after the initial design ect... I had a restaurant that grew too fast and needed a temp fix for additional cooling. Rented a portable 2 ton unit with a ducted condensor to the outside and ducted the return from a conditioned storage space (non greasey air). It took up some needed space, but when the kitchen temps got over 95*F, the space wasn't near as important anymore. Good luck!
