Results 14 to 24 of 24
    Dec 2008
    New York, ny
    -150 what you making this with..
    Sent from my SGH-T999 using Tapatalk 2
    Dec 2008
    New York, ny
    What you need it to be that low for.
    Oct 2005
    B.C. Canada
    Brain freezing, it wont get lower than -125 and theyr *****in.. used to run at 150
    University lab crap
    Is that a normal type walk in split system? What refrigerant does the -150 unit run on?
    Virginia
    So I swap in a new compressor , and shes running 250 high , 18 low , and it came down to 0 degrees easily
    I wasnt sure if that high side was safe (seemed a tad high ) so i called tech supp , they said yes , with the double cap tube setup , high averages 245 and low 14 - 20
    hmm , well alrighty then
    Dec 2008
    New York, ny
    What was your amps at?
    Virginia
    Was in a hurry and didnt bother checkin amps. With perfect pressures I was happy
    Oct 2011
    Chicagoland Area
    Quote Originally Posted by Snapperhead View Post
    That's a Bozo No no
    Local 597 Service Fitter
    Metal Trade Journeyman
    PAY ME NOW OR PAY ME LATER
    It was working when I left...
    WWFD
    Dec 2008
    New York, ny
    Always check amps when charging buddy.. just to be 100% sure.. and you can sleep at night knowing you did it all right
    Virginia
    I always do check amps , but on this I was in a rush and had the wires all tucked in nicely and side covers back on , wasnt about to remove all that again , I did entertain the thought because it was buggin me , but nawwww
    I still havent billed them, I might have time today to swing by and pull a wire out
    Virginia
    Pulling 6.4 amps with cond fan on
