Results 1 to 8 of 8
    Dec 2006
    Hi,
    I need to replace my 24 year old Pulse gas furnace
    (G14-q480) because of the carbon problem and it is out of warranty.
    One contractor offers the same price for a Lennox G61 or Trane TUX080R942W. Both companies have the same warranty.
    Please help me to choose one between those two systems. I am looking for a reliable furnace.
    Thank you very much in advance.
    PH
    Rochester, MN
    Not really apple to apple
    The Trane is a single stage 90% furnace.
    The Lennox is a two stage 90%.
    I'd go two stage with a 2-Stage T-stat for COMFORT.
    Not knowing where you are from, I'd look into the two stage variable speed system.
    Dec 2006
    thank you for quick response
    Hi Mayguy,
    I am in Maryland.
    I thought Trane TUX080R942W is a two stage furnace.
    Could you please recommend a couple 2 stage T-stat?
    The reason I did not want to spend money for a variable speed system because I won't be in that house for more than 5 years.
    Thank you so much.
    PH
    Rochester, MN
    My bad.. You are right, it is a two stage furnace.. The model's number are close so it kinda threw me off.
    I'd go with the Honeywell Pro lines Either the VisionPro or FocusPor t-stat.
    http://www.hotfreshcool.com/thermostats.html
    Both are very good t-stat, and if the installer is not able to pull wire to make it work with a two stage, then I'd go with the Honeywell IAQ, It will only use 3 wires, and then a control mounted on the return duct to tie the furnace to.
    Dec 2006
    Winnipeg-Mb.
    I personally would and have installed the Lennox g61-mpv-.
    your previous Lennox has lasted for 20 years, why not try the next generation of Lennox's furnace's.
    More efficient in saving money and noise volumes.
    Very nice furnace.
    i had a lennox g61v installed in july and love it i did look into a trane but it came down to the installer and im glad i took my time i also got a better payment plan and found out the trane company lost there contract with ???? HOMODEPOT. The company that did install it has bein great and the install was awesome
    Originally posted by acefurnacefixer
    seems like a cut and dry answer to me.......Lennox is by far the better unit.
    I wouldn't call a 13 point spread on a 1000 point scale "by far".
    That rating is based on questions asked of subcontractors.
    The rankings are based
    "Overall subcontractor satisfaction with HVAC manufacturers is based on performance in seven factors. They are (in order of importance): warranty and repair service (23%); sales and marketing support (18%); ordering process (16%); product (14%); credit/billing (11%); delivery (11%) and price (9%)."
    They do not reflect end user satisfaction or equipment reliability at all.
    Read the press release here:
    http://www.jdpower.com/global/press-...asp?ID=2006153
    Using that ranking as a sales tool to promote one product as better than another to consumers is dishonest, and possibly fraudulent IMO.
    The Consumer reports rankings, that are based on consumer feedback, have them in a totally different order...
    [Edited by mark beiser on 12-19-2006 at 10:51 PM]
    Rochester, MN
    I totaly agree with Mark on what he said.
    I don't go by what reports says..
