Results 1 to 13 of 14
    Buderus GB142 New Construction
    I know many of you busted my hump about not painting the board on this install....
    http://hvac-talk.com/vbb/showthread....-Family-Retail
    The pics below are of a new construction home being built by a local inspector.
    -all in floor
    -garage zone has antifreeze and is separated with plate heat exchanger
    -boiler buddy
    -alpha pump with zones
    -indirect dhw
    This is still a work in progress but I thought it looks great so far. The water line to the fill for the boiler was installed as a temporary thing by the plumber as he was in a hurry. I didn't do any of the piping but I designed the boiler board and will be completing wiring and start up probably next week. We also have installed a gas furnace, a/c and duct into this house.
    Click image for larger version.
    May 2012
    Upper Michigan
    Is that a heat trap instead of a check valve? Looks nice
    BoilerBuddy_Installation.pdf
    that wasn't what we were going for.... but sure!
    ironically, i looked up the instructions online for the boiler buddy (after my other boiler post) and found nothing noted about check valves either in writing or any of the drawings
    thanks for looking!
    May 2012
    Upper Michigan
    I think your right too, I always use them but after telling you I looked and think I didn't see them either.
    In a boiler room
    Good stuff Cody!
    May 2012
    Upper Michigan
    I'm thinking that diamond plate wasn't cheap?
    Poestenkill, NY
    Looks great! The diamond plate is a bit "much" - I guess you can't win. lol
    When using teh boiler buddy, stop using the supplied decoupler manifold! Needless extra pump!
    Jun 2002
    Upstate Central NY
    So the white tank is a buffer tank? Is this to increase the water capacity in the system and reduce short cycling?
    Installed many Mon/Cons - never with a buffer.
    May 2012
    Upper Michigan
    Quote Originally Posted by edbrown View Post
    Thermal mass, your correct, if it can't modulate down below the lowest load it will short cycle.
    Palmyra MO
    Looks good how much did the stainless plate cost?
    the diamond plate i think was actually aluminum, we mounted a 4x8 sheet of the plate to plywood and it's mounted and anchored to the wall but with a 1/2" gap so as to avoid moisture issues
    thanks for looking
    Jun 2011
    Seattle WA
    Diamond Plate!!
    -Alfred E Newman
    Quote Originally Posted by LibertyTree View Post
    Diamond Plate!!
    Yeah! haha
