Results 1 to 13 of 29
    Mar 2010
    New Haven, Indiana
    2 stage furnace.
    Do you setup 2 stage furnace with single stage stat and let the board control 2nd stage. Or install 2 stage stat and let stat control when to turn on second stage. Just wanted to see which way other Techs would setup new installs.
    SE Michigan
    If you set it up with a single stage stat, then it will not function as a true 2 stage furnace....it will simply work off a timer.
    Mar 2010
    New Haven, Indiana
    True. But wouldnt it be more for comfort
    Atlanta GA area
    Both ways... Yeah, that is confusing.
    I sell more VS drive furnaces than PSC... depends on the customer and what they buy.
    If I am replacing a system with basic equipment and I sell them up to a VS furnace and media filter (most sales); then I use a single stage stat and set the furnace for either 5 or 10 min delay to high. Many installs the furnace does not go into high many times the whole heating season (note I am in a warmer climate).
    When the customer buys a nicer system... all of the above plus 2 stage AC... then I generally sell them a high end stat... like the HoneyWell Prestige IAQ YTHX9421R5069 or 5077. Customers seem to like the systems I install... they keep referring me to their friends.
    GA-HVAC-Tech
    Jun 2001
    A 2 stage thermostat should be part of the quote for a 2 stage system if the customer doesn't already have one.
    stat, always.
    Grand Rapids, MI
    Our company does the two stage furnace with the single stage stat all the time and set the furnace for the 5 min delay.
    We had alot of complaints with 2 stage t-stat, because the furnace would run on low tooooo long ( mental hurdal for the client ).
    It's already bad enought with the older clients " the air isn't hot - turn it up ".
    luck dan
    Mar 2010
    New Haven, Indiana
    we sell 2 stage furnace with single stat. Furnace runs on 1st stage for 15 - 20 minutes then goes into 2nd stage. The Control Board is operating system. Which way is better for the customer? I would think running longer on 1st stage would make the house feel warmer throughout.
    Jul 2010
    nebraska
    We do both. Depends on if the customer wants to spend a little extra or bare bones minimum.
    Chester County PA
    How often does a customer buy a 2 stage furnace without a 2 stage air conditioner? Why would you force a furnace to run for 5-10 or even 20 minutes before kicking in to second stage when the customer just turned the thermostat up 6 degrees?
    Why not sell the customer full functionality?
    ~smoke~
    "That motor's done, he let the factory smoke charge out!"
    May 2011
    tallahassee,fl
    Depends on stat wire, our Tstats are single or 2 stage so if the wires are there then stat if not then board. On high end we pull new wire. Case by case
    Austin, Texas
    My criteria is whatever the boss ordered.
    Chester County PA
    nismo1, check out the Honeywell wireless stats. You can get them in a Focus Pro style up to the Prestige line. 2wire or no wire applications
    ~smoke~
