Results 1 to 11 of 11
    Dec 2010
    Mooresville
    Door Frame heater
    hello i got a question im working on a victory reach in refrigerator Model-Raa-2d-s7 and apparently. the door frame heater wire on one of the corners some how got damaged by the door opening and closing all the years.Was wondering if its possible to just solder in a small extension piece of wire or would that be to dangerous or should i just buy one of the universal heater wiring kits the refrigerator is of my personal use . thank you
    Jul 2012
    North west Arkansas
    Replace it. Do it right.
    Jul 2012
    Western KY
    Never tried to repair one myself so don't know if is worth the effort. They are inexpensive so just replace.
    Oct 2009
    Raleigh, NC
    Is it sweating? If not, just disconnect the heater and let it go.
    Oct 2011
    Chicagoland Area
    If you're repair breaks someone could get zapped. Just replace it. If it's on a cooler, like MicahWes said, you may not even need it.
    Jan 2013
    Central Arkansas
    replacing would be the safer repair and also posssible ly prevent a call back
    I've repaired them in the past.
    Faster than replacing them when you're running 100 miles an hour in the summertime.
    Typically not necessary to solder an extension on, just start ripping into the wire and you'll see why.
    Mar 2009
    Chicago Area
    I have replaced a few on freezer walk in doors no problem repair order the new part install
    Quote Originally Posted by keekee View Post
    I've always replaced the trim when doing WIF heaters. Once removed they never seem to go back in easily. If they go in they never look the same
    Sent from my SGH-T999 using Tapatalk 2
    Apr 2010
    working overtime
    Quote Originally Posted by hvac wiz 79 View Post
    X2
    Mar 2009
    Chicago Area
    T Y Good tip last one came off and went back on easy. will order trim next time so I won't have to make two trips.
