Page 4 of 5 FirstFirst 12345 LastLast
Results 40 to 52 of 59
  1. #40
    Jan 2013
    Quote Originally Posted by firecontrol View Post
    Whoever it was, either didn't have the correct information to input into the "fancy software", or their professional status is in another field other than hydronics. Why? Because the capabilities of the pump you are using fall far outside of the conditions you have it installed in. That's according to the Taco software that I use to design or verify every hydronics/radiant system I build or work on.
    And before you ask "then what pump should I be using", let me once again stress that supplying that information would be in direct violation of the posted rules that I agreed to when I was granted permission to post here as a pro.
    then thx for nothing
  2. #41
    Aug 2012
    the system needs the proper pump and piping parameters to work as designed, taking shortcuts just costs more money in the long run.
    It's not if your doing it right it's whether your doing the right thing that is important.
  3. #42
    Jan 2013
    Every "Expert" I talk to sayz that the other guy doesnt know what he's talking about.
    Story of my Hydronics life
    Greg
  4. #43
    May 2012
    Upper Michigan
    We're are you located? There might be a member here In your area.
  5. #44
    Aug 2012
    Too bad the expert their talking about is you. An engineer should have designed your hydronic system followed by a qualified installation company to install it using proper install practices that can only be learned thru schooling and OJT. This is not something you can do by following the directions in the install manual- obviously.
  6. #45
    Jan 2013
    Quote Originally Posted by toocoolforschool View Post
    Do me a favor and un-follow this thread
    Thx
  7. #46
    Aug 2012
    I guess you can't face the facts of good money you wasted trying to take a short cut, don't be mad at me for pointing out the facts of your situation; time to pay the piper and stand up swollow your pride and ego. Or just listen to the hammering sound from you brand new system.
  8. #47
    Saint Joseph, MI
    Quote Originally Posted by Greg555 View Post
    50/50
    Why 50/50?
    Looking at my handy chart (I deal in industrial chillers at my work):
    25% = 14F
    30% = 10F
    40% = -6F
    50% = -28F
    Keep in mind the pipe burst rating is much lower temps. Meaning the freezing point is when the liquid is sitting in an open bucket and starts to turn into slush. Slush won't pump, but it won't destroy piping. 24% will get your burst protection to 0F, which is probably all you need.
    http://msdssearch.dow.com/PublishedL...romPage=GetDoc
    To be honest, most cars probaly don't need 50%, but they are some and operated in such a wide range of location, that they play it safe. FWIM, we use 20-25% in our chilled water system so we can run 32F water temps, keep CW coils in 100% outside air handler from bursting if hte pumps or steam reheat fails, and lastly, I think 15-20% is needed ot prevent bacteria growth... obvisouly not an issue in a hot water boiler that runs over 120F.
    Maybe just try dropping the glycol percentage and see what happens.
  9. #48
    Jul 2000
    Northern Wisconsin
    Good luck Gregg with resolving your issues.
    I'd continue to try and help in anyway I could (or am allowed to) if I felt it would make a difference, but I sense that won't be the case.
    All of the threads in this forum provide information in one form or another to all those that read them. This thread is no different.
  10. #49
    Quote Originally Posted by Joehvac25 View Post
    I believe there are at least 2 members of this board that service his area. And would know how to fix this set up.
  11. #50
    May 2012
    Upper Michigan
    How'd you get his location? Either way a member on this forum would be the best especially since they have good support here
  12. #51
    I'm a mod. I can see the IP of any poster.
  13. #52
    May 2012
    Upper Michigan
    Ya I kinda figured that, they must have to use there area for an application, can't remember it's been awhile.
