Page 1 of 4 1234 LastLast
Results 1 to 13 of 40
    Jan 2013
    Help! American Standard 18SEER
    This is one of those buddy deals over the phone so i dont have any info besides this..it's been in the mid 30's & raining and his 2 stage heat pump is froze so big at the top that the fan blades are hitting the ice. The rest of the condenser has no ice at all. He called the nearest AS dealer & they said dont worry about it that all of them are doing it bc of the weather. I havent looked into it & have very little experience with AS, just wanted to hear some thoughts.
    Jan 2013
    AS 18 SEER freezing
    Delaware
    Is water falling from the roof/gutter right on the top of the unit?
    Always here
    Jan 2005
    Emerald Coast
    Heat pumps and freezing rain is not a good thing. Have them switch over to their aux heat
    until temps warm up and the sno cone thaws.
    Do not attempt vast projects with
    half vast experience and ideas.
    Jan 2013
    Was looking for a technical explanation. I already know that heat pumps suck and they have supp heat. But it shouldnt freeze enough to hit the fan blades if it was working properly.
    Jan 2013
    No but it has been steadily raining for 5 days. But that still doesn't explain the top few rows being all that freezes does it?
    Atlanta GA area
    Well... maybe
    Think with me: The fan sucks air over the coils... and blows this cold air out the top. In many cases, the temp of that air is below freezing. So where do you think the ice will form first?
    May be different on different machines...
    This is why I prefer a Demand rather than a Timer defrost board. They tend to catch this sooner... yet not defrost until it is needed.
    GA-HVAC-Tech
    Jan 2013
    Ok, I'm going to think out loud so correct me when I'm wrong. "Freon enters the bottom of the condensing unit (evaporator in heat mode and coldest point of the cycle), absorbs latent heat until it becomes 100% vapor and continues out the top constantly gaining superheat (which would be its warmest point)." That's my thinking so now why would it only freeze at the warmest part of the process?
    Trane is demand. Mid 30s and pouring rain could cause weird things. Usually sensors are mounted low so could be that icing was so bad that the sensor detected a warm coil low down and stopped the defrost. I'd go on em heat and see what happens under normal conditions.
    Jan 2013
    They have 2 identical units put in at the same time. The other is on a different house a couple hundred yards away and it freezing evenly like normal.
    In a machine room
    They need a good tech, that is not normal under any weather. Trane/Am Std with demand defrost almost never have defrost issues.
    I would start by thawing it out completely and then running it and observing the frost pattern.
    Jan 2013
    I am going to go check it for them when the rain stops. I'm new to this site so I posted it here to see if there was really any "techs" or "professionals" on this board. So far i've mostly seen parts swappers. Smh
    Chester County PA
    Heat Pumps don't "suck", it might be under charged if only half the coil is freezing up. If it has a defrost sensor it might be located at the other end of the coil and not reach the specified temp to kick it into defrost.
    It doesn't have to be a "AS" tech, it needs to be a competent tech.
    ~smoke~
    "That motor's done, he let the factory smoke charge out!"
