Results 1 to 9 of 9
    Palmyra MO
    Triangle Tube Boiler Install
    Floor heat in a garage. Really nice system.
    Palmyra MO
    128 views and not one single complaint or compliment? Im confused?
    Cincinnati, Oh
    Quote Originally Posted by drife678 View Post
    Having problems seeing the near boiler piping, but:
    Looks like your pumping the wrong way.
    No P/S requirement?
    I do like your infloor hookup.
    "Just get it done son."
    Dad adjusted
    May 2012
    Upper Michigan
    Ya pump away from air scoop, looks nice and clean.
    Mount Airy, MD
    Relief and back flow is?
    Dec 2009
    Southwestern Ontario, Canada
    Quote Originally Posted by Chris_Worthington View Post
    I see the relief. Its the copper pipe coming down on the right side of the boiler with 2 90s to offset to the floor.
    May 2012
    Upper Michigan
    Must be a 60k?
    Cincinnati, Oh
    Quote Originally Posted by copperteeth View Post
    Yep. Last triangle's I did had relief/air vent tapped on top of the boiler.
    I don't see a backflow, and I see alot of missing valves.
    Dad adjusted
    Palmyra MO
    Backflow and automatic fill enter between exspansion tank and air seperator.
