Page 8 of 9 FirstFirst 123456789 LastLast
Results 92 to 104 of 107
  1. #92
    Jun 2012
    Feng is a genius.
  2. #93
    Jul 2012
    Western KY
    They gone
  3. #94
    Oct 2009
    Ontario, Canada
    Nope. Hes out putting propane into systems.
    Read the comments too. I really love it when people think they NEED air conditioning. I didnt even have a window banger until I turned 22.
    Get money, get paid.
  4. #95
    Pittsburgh
    Quote Originally Posted by fengshvac View Post
    Problem: heat pump produce no heat, only blow cold air.
    Insight: Called for heat, Blower ran, but compressor didn't come on.
    Cause: dirty air filter cause the high pressure switch to trip during heat mode.
    Solution: While it was calling for heat, checked 24v on the Y wire from the thermostat at the unit, got 24v. checked 24v at the compressor contactor coil, no voltage. found High pressure swith is in between, reset it. cleaned the air filter, turned the heat back on.
    Attachment 347281Attachment 347291Attachment 347301
    This High pressure do flicky thingy. I am totally confused as to its function and how it knew the filter was dirty ? Would you please elaborate on the subject ?
  5. #96
    Panama City, FL
    I believe we've found the man who writes the I/O manuals for all of those imported mini splits.
    You can't learn a thing with your mouth open.
  6. #97
    Feb 2007
    Helena, Montana
    Feng, WHERE ARE YOU??? You are needed on the "I'm so confused thread". They coud use your wisdom.....
    Don't worry zombies are looking for brains, you're safe...
  7. #98
    Oct 2011
    Chicagoland Area
    He still lurks around. I see his name once in awhile on the logged in list at the bottom of the main page.
  8. #99
    May 2011
    Western, KY
    There was a sitting : )!!!
    http://hvac-talk.com/vbb/showthread.php?t=1250451
    He gave just enough in his post to leave us wanting more!
  9. #100
    Nov 2011
    St. Louis
    He better still be here...I spent more than an hour over the weekend on a tribute/testament to him down in the fitness room by the pub.
  10. #101
    Jan 2013
    San Gabriel Valley, California
    Sorry guys, after a few posts and I saw some reply and they looks like spams. So I thought u guys are just machines, and that's why I stop posting. Hahahah
  11. #102
    May 2011
    Western, KY
    If you get 15 posts you can apply for pro membership and do as in depth and technical walkthroughs as you want in the locked pro forums, you also might find out some things even you didn't know.... : )
    Seriously though keep posting.
  12. #103
    Jan 2013
    Where is the "I am confuse" thread?
  13. #104
    May 2011
    Western, KY
    I believe it was in the AOP(ask our pros) section but you have to be a pro member and approved to respond to those posts.
