Results 1 to 13 of 19
Thread: Water Furnace
    Aug 2012
    Palmyra, Missouri, United States
    Water Furnace
    New construction home with three zones.
    Jan 2010
    Got anymore pics ?
    Belimo controls ?
    Aug 2012
    sorry. only one i took. trying to upload some other jobs.
    Jul 2009
    Columbia, MD
    looks like the orange EWC's
    Aug 2012
    belimos
    Sep 2012
    Michigan
    Looks Good!
    Jan 2013
    Champaign Illinois
    I don't have much experience with water furnace, but I have a lot with geocomfort does this unit have a variable speed blower?
    Aug 2012
    Yes
    Jan 2013
    Champaign Illinois
    Well job looks very nice. One small thing though, the variable speed blowers require a min. Of 18 inches of the plenum height to be the same size as the opening on the top of the unit. The reason why is because the blower needs to have the resistance of the pressure of the duct as it try's to find the proper speed. The transition ( while nicely done) will not allow this to happen and you will experience harsh " huffing " noises and uneven airflow. This can cause the loss of capacity and motor damage. Other than that nice job.
    Aug 2012
    We have thousands identical
    Jan 2013
    Champaign Illinois
    Perhaps they use a different blower than geocomfort. I have also had the same problem on the climate masters. Last one I found was done with duct board and it sounded like someone was moving furniture around upstairs as it ran.
    Aug 2012
    Lol
    Aug 2012
    The zone panel controls 5 diff fan speeds most of the time its in low unless there's possible problem and electric heat is on then it flat gets it.
