Results 14 to 25 of 25
    Jan 2010
    Why hard pipe on the suction ?
    Jul 2001
    Anderson,SC
    Sounds good to me,good luck.
    Stud
    Looks nice
    sent from my kindle fire using tapatalk 2 please excuse any typographical errors using tapatalk
    If you can not do it right, Why even do it at all?
    Jul 2012
    Western KY
    Very nice. May regret not running the lineset along the wall and 90 straight out to unit.
    Jan 2001
    Sherwood Park Alberta
    Why is the overflow on the evapoartor coil not piped in?
    What happens to the water when the primary drain plugs up?
    Jul 2012
    Cincinnati ohio
    Quote Originally Posted by Servicepro View Post
    Nobody pipes them in around here either. I have seen a few that were piped into the primary which makes no since at all.
    Apr 2011
    West of DFW
    On up-flow units we install a safety switch. It's code.
    I don't want to hear you complaining!
    Sep 2012
    Michigan
    We usually have a safety that we put/wire in. the maintenance guy that takes care of the building said he didnt need one because he is in the mechanical room every day
    Apr 2011
    West of DFW
    Quote Originally Posted by coens View Post
    I am in my house everyday too...maybe I don't need my smoke and CO detector.
    Nov 2011
    East Side
    I would have 90'd from the building rather than 45'd....personal preference really....less line hanging in the open. also don't see a point in rigid on the SL.
    are you saying the combustion condensate was internally trapped, or the coil is internally trapped?
    I also would have shortened the 'T' and capped it on the drain line. shouldn't be any issues unless static is high.
    also snow legs on the furnace to keep the metal off the concrete (if you have the room), and the same on cond. keeps both from rusting early, and allows cond. to drain without getting crap plugging up the drains.
    overall nice job though!
    Jan 2001
    Ive been to a few calls were the overflowed water got into the furnace control board....water and control board bad marriage
    Jun 2009
    Alberta, Canada
    dont need a trap, it's under positive pressure... but it does need atmospheric vent
    Have tools and gauges, will travel.
    RIDGID|YELLOW JACKET|UEI|TESTO|STANLEY|CPS|VETO| KLEIN|MILWAUKEE|MASTERCRAFT|
