Results 14 to 18 of 18
    Saint Joseph, MI
    Sounds like they may be getting to the root of the problem. Youll find that outside of setbacks than, you probably dont even need more than low stage other than for a few hours on the coldest days.
    Sent from my SGPT12 using Tapatalk 2
    Apr 2012
    Cool
    IT'S FIXED!!!!!!!!!!!!!!!!
    On Saturday, they installed a new limit switch. Got a system malfunction on Sunday, early morning. I lowered the thermostat to 68 so as to not stress the furnance and the new limit switch.
    On Wednesday, they replaced the blower motor. BINGO. Everything works great now. The temperature inside the furnace on max heat via probe reading is around 155 and that's with the humidifier bypass damper open and the new vent that was installed just above the A/C coil for heat relief completely closed. Static pressure is now 0.61.
    I am so happy its working finally. Thanks to everyone here who read and responded to my saga. Having additional input on the situation really helped.
    Jun 2006
    Richmond, VA
    Quote Originally Posted by joeWI View Post
    I still wouldn't be happy. The temp rise for that furnace is 35 to 65 degrees. so even at 70 indoor the max outlet temp should be 135.
    "Decidedly Superior in a twisted pathetic way".....
    Saint Joseph, MI
    I wonder if the bypass humidifier is bypassing too much air. On some you can adjust the damper to reduce flow. I agree that 135F should be max. Something still doesn't seem right. Gas pressure/Overfired?
  5. Likes DeHeatify liked this post
  6. #18
    butler pa
    sounds a bit too toasty warm..think on the carriers ya gotta adj high first,then med,then low. havent played w one of the 3 stage infinitys..
  7. Likes DeHeatify liked this post
